C4 steering column bushings
Old Aug 24, 2005 | 06:31 PM
steve40th's Avatar
steve40th
St. Jude Donor '03 & '05
Default C4 steering column bushings
Anyone ever replace these? My steering column bushiungs mustbe going. I can take my steering wheel and move it about an inch and a half from , approximately, 2 O'Clock to 7 postion.
Old Oct 29, 2005 | 04:39 AM
86PACER's Avatar
86PACER
Dang, that's a lot of play.
Old Oct 29, 2005 | 05:51 AM
86PACER's Avatar
86PACER
Old Oct 29, 2005 | 08:40 AM
Greg Gore's Avatar
Greg Gore
Default Excessive Steering Play
How many miles on the car? There is an intermediate shaft with a universal joint that couples the end of the steering column shaft to the steering rack. Check to make sure the bolts are tight at the couplings on each end of the imtermediate shaft. Check for play in the universal joint. Have your steering rack checked. This much play would imdicate to me an imminent failure and it needs to be fixed before you drive the car again.
Regards, Greg
Old Oct 29, 2005 | 01:04 PM
steve40th's Avatar
steve40th
It doesnt move more than an one inch guys, I am sorry. I was referring to the 2-7 position it moves. I have had the rack replaced before to fix it as it was cheaper. But that was on the mainland. I just dont remember if you can just do the bushiings.
Old Oct 29, 2005 | 05:31 PM
No Go's Avatar
No Go
What about the tilt mechanism/pivot? I seem to remember the C4 had some issues with that portion with too much play, etc...
Old Oct 29, 2005 | 08:37 PM
TRACK MAN's Avatar
TRACK MAN
There Is A Jiont Hikie Right Below The Bender That Needs Replaced... The Same Thing Hapened To Mine. I Got It Replaced And Now Every Things Fine...its Part Of The Shaft / Colum Like A
U-joint ... Sorry Im More Of A Driver Than A Mechanic.......
Old Oct 30, 2005 | 01:28 AM
steve40th's Avatar
steve40th
[QUOTE=TRACK MAN]There Is A Jiont Hikie Right Below The Bender That Needs Replaced... The Same Thing Hapened To Mine. I Got It Replaced And Now Every Things Fine...its Part Of The Shaft / Colum Like A
U-joint ... Sorry Im More Of A Driver Than A Mechanic.......[/
Cool, if you could take a picture or ask the mechanic what part and where he ordered it. I really need to fix this.
Old Oct 30, 2005 | 01:02 AM
cv67's Avatar
cv67
St. Jude Donor '05
Ditto
To C4 steering column bushings
