torque converter install
I'm going to install a new converter this weekend to get rid of that dreaded shudder. My problem is I've never install a new on before and need a little advice.
First when seating the converter in the transmission how will I know that it is fully seated? Is there a measurement?
Second should I add fluid to the converter before installing and if so how much??
When you have every thing bolted up, the convertor usually has to pulled foward a fraction to bolt up to the flexplate.
When removing trans ,wire convertor in place so it does not slip foward and spill fluid every where.
As far as install I put as much fluid in the converter that will stay in when lifted vertical to mount on trans.
Piece of cake!
