Idle keeps "blipping"
Old Aug 26, 2005 | 10:22 AM
94Controller's Avatar
94Controller
Default Idle keeps "blipping"
After my 94 warms up to about 200, and I'm sitting at a light, the idle will jump, or blip (as I call it), just for a second. Does it every 5 seconds or so and if I'm not holding the brake good, it'll roll a couple inches. It does this with the A/C on or off. Driving me nuts, any ideas what would cause it? Time to take the throttle body off and clean it?
Old Aug 26, 2005 | 12:47 PM
94ZR1's Avatar
94ZR1
St. Jude Donor '06
Yes Clean the TB and check the IAC while you are there Could also be TPS but I doubt it
Old Aug 26, 2005 | 01:14 PM
Knight Ryder's Avatar
Knight Ryder
St. Jude Donor '05-'06-'07-'08
While I never had this problem with my '96, my old 3000GT would "bounce" at idle. The problem ended up being a bad idle airflow servo. Easy bolt-on fix if I remember correctly. You may want to check that out.
Old Aug 26, 2005 | 04:20 PM
mjfox's Avatar
mjfox
I would check your ohm readings on your fuel injectors sounds like when it gets hot it is letting fuel in at the wrong time .All injectors should be with in 1 ohm.Mine is a 92 LT1 12 ohms.Yours may be different.
Mike
To Idle keeps "blipping"
