Same thing? Or separate problems?
Old Aug 26, 2005 | 06:38 PM
nw92vert's Avatar
nw92vert
Default Same thing? Or separate problems?
For the most part my car runs pretty well. But almost every morning on the way to work if I run at lower RPMs in 6th (below 1500) up the hill I have to drive over it will miss. Usually it'll do fine if I go down a gear. And then there's the times when I try to aggressively insert myself into traffic and nail the throttle in 1st from a stop. Many times it'll just fall flat on its face. Fortunately I haven't caused any real problems when this has happened, except for maybe the cars behind me thinking they can go too and are surprised when I hardly move.
Any thoughts? Injectors? Vacuum leaks? ECM?
Thanks guys.
- Glenn
Old Aug 26, 2005 | 06:48 PM
stanandsue's Avatar
stanandsue
have you tried pulling diagnostic codes to narrow this down? I got the following link from bogus:
http://www.c4guru.com/articles/CCMCodePull.pdf
if you have not done this yet, I suggest it as a good next step
Old Aug 26, 2005 | 08:35 PM
CFI-EFI's Avatar
CFI-EFI
DOWN SHIFT!
You are lugging the engine. That is Corvette abuse. Punishable by...
RACE ON!!!
Old Aug 26, 2005 | 08:54 PM
ittlfly's Avatar
ittlfly
[QUOTE=CFI-EFI]DOWN SHIFT!
by ......... this reply. Sorry CFI-EFI, I couldn't resist.
Old Aug 26, 2005 | 09:02 PM
CFI-EFI's Avatar
CFI-EFI
Originally Posted by ittlfly
Punishable by...
If you can't do the time, don't do the crime.
Check for codes, my...
RACE ON!!!
Old Aug 26, 2005 | 09:12 PM
ittlfly's Avatar
ittlfly
Old Aug 26, 2005 | 09:46 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
nw, just be a tad less quick to shift up to the next gear especially 6th gear. The first gear drop off doesn't sound normal. Something to be looked into.
Old Aug 26, 2005 | 11:38 PM
nw92vert's Avatar
nw92vert
Pardon my ignorance, but I am under the impression that codes are only posted when an error lite comes on the panel. There are no error lites. Does the control module talk even when its not turning on error lites?
- Glenn
Old Aug 27, 2005 | 12:20 AM
nw92vert's Avatar
nw92vert
I just ordered a Helms Manual and printed out the CCM Code Reading guide by C4 Guru. Thanks for pointing me in the right direction.
- Glenn
Old Aug 28, 2005 | 09:42 AM
stanandsue's Avatar
stanandsue
'good step - and it's easy to do - let us know if you find anything
To Same thing? Or separate problems?
