Wiper Crash!!
Old Aug 27, 2005 | 11:25 AM
jimkari's Avatar
jimkari
Default Wiper Crash!!
Has anyone had the problem of wiper arms hitting each other on a C4? My '93 arms appear to chatter across the windshield and at times hit each other. I've tried new wiper blades. I've also cleaned the windshield and use rainX to help them side. Is it possible my linkage is loose or the motor is starting to go bad and just doesn't have the power to side the wipers without chattering? Any ideas??
Thanks,
Jim
Old Aug 27, 2005 | 11:29 AM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
Lift your wipers up and wiggle the wiper back and forth.Too much play will cause this especially on the drivers side.I bought a new one for that side and even though the pass side needs replaced it no longer crashes.The hold down springs also get weak which would cause the chatter.
Old Aug 27, 2005 | 01:01 PM
VenkmanP's Avatar
VenkmanP
For the hitting problem:
https://www.corvetteforum.com/techti...D=42&TopicID=2
Old Aug 27, 2005 | 05:09 PM
janman's Avatar
janman
Default Wiper Crash
The tech topic mentioned is good I just finished doing it to my 88 for the same problem. Thats the good news, the bad news is that somewhere along the way someone treid to adjust out the problem and now I have to re-adjust the linkage to where it should be. I have all the Facotory books and they are silent about how this is done. Anyone know about that ? You may have to do that . The arms now cost 30 bucks each from GM. I got mine from GM Parts Obselete for half that. I also got the blades from PEP boys.---good luck
Old Aug 27, 2005 | 05:49 PM
Redeasysport
Yes people try to do the adjustment(it IS in the FSM)when the problem is worn out arms instead then it is really messed up when you get new ones.
Old Aug 27, 2005 | 06:27 PM
tobijohn's Avatar
tobijohn
Bench Racer
St. Jude '03 thru 14,'25
Another "down and dirty" fix is to use a shorter arm on the drivers side. I think the later C4 blades are 20" so try a 19" blade (or whatever is an inch shorter than what you've got now. If your wiper arms are NOT worn out, you could try the adjustment (see subsequent post)...
Old Aug 27, 2005 | 06:28 PM
tobijohn's Avatar
tobijohn
Bench Racer
Here's the adjustment instruction for my 96 out of the Helms:
Old Aug 27, 2005 | 06:36 PM
Redeasysport
I want to stress DO NOT do the adjustment until you are sure the arms are not worn out.
Old Aug 27, 2005 | 07:18 PM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
Thanks, Redeasy. That's good advice re checking first on whether the arm is worn out or not.
Old Aug 27, 2005 | 08:51 PM
Redeasysport
Been there done that Another thing that I found interesting in the process is how far the new arm has to be twisted up to fit onto the wiper stops.They are REALLY preloaded it seemed like the wiper arm was 3 in below the stops.Just lift it up over them and set it in place.
Old Aug 28, 2005 | 02:07 PM
janman's Avatar
janman
Default Wiper crash
Thanks for the follow up. My arms are new and it appeared someone tried to adjust it out with the old style arms.
Thanks Again.
To Wiper Crash!!
