I Need Help!!
Old Aug 27, 2005 | 05:42 PM
86malcomekonnner's Avatar
86malcomekonnner
Default I Need Help!!
I'm rebuilding an '86 and i i forget what hose attaches to the upper left side of the throttle body. PLEASE HELP
Old Aug 27, 2005 | 05:53 PM
bogus's Avatar
bogus
All references to "side" when dealing with an engine component are made from the drivers seat. So the left is drivers side, right is passengers side.
With that said, left side? nothing. It's only the cables over there.
The right, now that's different. There are the coolant lines, which I would bypass... the PCV line and another vacuum source for the evaporative emissions.
Under the TB is a vacuum source for the EGR, I think.
Old Aug 27, 2005 | 06:20 PM
REDC4CORVETTE's Avatar
REDC4CORVETTE
The vaccum source it pulled from the plenum at the pass side rear.
Old Aug 27, 2005 | 07:24 PM
_twisted_'s Avatar
_twisted_
Take a pic 86, I am curious to see if you have 2 nipples on the TB by the TPS or just 1.
Old Aug 28, 2005 | 10:25 AM
86malcomekonnner
The TB has 2 nipples one above the TPS and one below it.
Old Aug 28, 2005 | 02:00 PM
bogus's Avatar
bogus
the big nipple is for the PCV, the small, for evap emissions.
check the sticker on the radiator shroud.
Old Aug 28, 2005 | 06:35 PM
86malcomekonnner
the big nipple is a coolant inlet for the TB which then goes to the left side of the TB and into the intake manifold. i think the top nipple is for the PCV?
Old Aug 28, 2005 | 07:03 PM
_twisted_'s Avatar
_twisted_
My 86's tb had 1 for the pvc - I didn't mean the nipple for the coolant.
If you look directly below the pcv nipple there should be a void for which the "other" vac line would go to, if there was a need for it on "our" 86's, my new 52 mm tb has both and I am going to cap the lower.
86MK- on your drivers side valve cover where the pcv hose goes to a tube - at the front of that tube is there a nipple with a hose on it? mine has the nipple and nothing else.
I would snap a photo but the car isn't here.
To I Need Help!!
