Oil Pressure Shut Down
Old Aug 28, 2005 | 04:14 PM
drochau's Avatar
drochau
Default Oil Pressure Shut Down
Hey guys. I'm running a 96 LT4 with a Procharger. When I am racing and run the car near red line it shuts down and the oil pressure drops out. The car will not turn back on until the oil pressure recovers which usually takes about 30-40seconds. It's mind numbing to think the car could shut down at any time. It didn't happen during tuning. My oil is 5w-30. I've been told by some racing buddies to switch to 15w-50 and replace the plugs with a smaller gap. This isn't a symptom of spark blowout from the supercharger right?
Old Aug 28, 2005 | 04:26 PM
CFI-EFI's Avatar
CFI-EFI
It sounds like you're hitting a rev limiter of some sort. If the engine is still turning, whether it's under power or not, then the oil pump is still turning. We have no way of knowing what rewiring may have been done to the car, but with a stock system and a functional fuel pump relay, oil pressure has nothing to do with the ability of the engine to start or run. Maybe trouble shooting of the fuel pressure relay is in order.
RACE ON!!!
Old Aug 28, 2005 | 04:37 PM
mash557's Avatar
mash557
Just a thought, does this have a stock oil pump or high volume. You could be sucking the pan dry, which would trigger the low oil pressure switch.
Old Aug 28, 2005 | 05:32 PM
drochau's Avatar
drochau
It's a high volume oil pump.
Major problem if it's fuel system-hard to repeat the situation, sounds like a nightmare.
Old Aug 28, 2005 | 05:34 PM
Morley's Avatar
Morley
Actually a high volume pump may be the cause of the oil pressure loss. It is emptying the pan very quickly and no oil has had a chance to get back down there before you loose pressure.
There are a couple of ways around this if you have a HV pump and want to keep it. First is a pan with 2 qts more capacity and second is an oil accumulator. This device holds oil (2 qts usually) under pressure, when the engine's oil pressure drops below a set point the accumulator will release its pressurized oil into the engine and prevent starvation. When the iol system recovers, the accumulator is automatically refilled with the extra oil.
Old Aug 28, 2005 | 05:40 PM
drochau's Avatar
drochau
I'm not very familiar with oil acumulators. What's a good one and what do I need for the install?
Old Aug 28, 2005 | 06:20 PM
CFI-EFI's Avatar
CFI-EFI
There is no "low oil pressure switch" that could shut down the engine, if it is properly wired.
RACE ON!!!
Old Aug 28, 2005 | 06:47 PM
mash557's Avatar
mash557
If the low oil pressure switch does not shut down the engine then what is it's purpose?
Old Aug 28, 2005 | 08:41 PM
Morley's Avatar
Morley
http://forums.corvetteforum.com/show...post1551794541
Old Aug 28, 2005 | 08:43 PM
Morley's Avatar
Morley
To provide a way to power the fuel pump if the relay goes out.
Old Aug 28, 2005 | 09:25 PM
CFI-EFI's Avatar
CFI-EFI
First, it is not a "low oil pressure switch" It is an oil pressure switch that is activated at approx 4 psi of oil pressure. It is a back up to power the fuel pump in case of a fuel pump relay failure. Don't believe me? Go pull the wires on your oil pressure switch and see if it kills your engine. If it does, you need a new fuel pump relay. Check your factory service manual. It will tell you how it works. Posting wrong info like that can only confuse people, like you are (were).
RACE ON!!!
Old Aug 29, 2005 | 03:39 AM
drochau's Avatar
drochau
So which should I do first? The accumulator or the oil pan?
Old Aug 29, 2005 | 10:47 AM
CFI-EFI's Avatar
CFI-EFI
I'd start with the pan and see what that does. An accumulator takes up a bit of room and it may be difficult to find a place for. Is this drag racing?
You've made a comment that is puzzling. "The car will not turn back on until the oil pressure recovers which usually takes about 30-40seconds.". How does the oil pressure recover, to "turn back on" if the engine isn't running (turned on?)?
RACE ON!!!
Old Aug 29, 2005 | 10:51 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Originally Posted by CFI-EFI
"[I]How does the oil pressure recover, to "turn back on" if the engine isn't running (turned on?)?
Old Aug 29, 2005 | 06:22 PM
mash557's Avatar
mash557
Okay CFI-EFI, the oil pressure switch feeds circuit 120 to the ECM for Fuel Pump signal. What does the ECM do with this information?
Old Aug 29, 2005 | 07:55 PM
CFI-EFI's Avatar
CFI-EFI
In my schematic, circuit 120 is the power wire to the fuel pump. Running backward, it goes from the pump, through the body connector to the fuel pump fuse. The circuit number changes at the fuse. From the fuse it it becomes circuit# 458 and it goes through the I.P. connector and connects to terminal 17 of the ECM AND has three other feeds. One is from terminal "G" of the ALDL, the second is from terminal "A" (the 12 volt output) of the fuel pump relay, and the third is from the N.O. oil pressure switch. Circuit# 458 allows for the simultaneous powering of the fuel pump from three independent sources. Had you given your schematic more than a cursory look, I wouldn't have had to explain all that. It was right in front of your nose all along.
RACE ON!!!
Old Aug 29, 2005 | 08:27 PM
CentralCoaster
So you can ground a pin on your aldl to turn on the pump, useful for emptying the tank. (or do you have to put 12v to this pinout?)
To Oil Pressure Shut Down
Old Aug 29, 2005 | 09:17 PM
CFI-EFI's Avatar
CFI-EFI
You don't ground it. You have to power it with 12 volts. Terminal "G" the fuel pump test terminal in the ALDL. In later cars it is either a different terminal, or "G" is in a different location. And, yes, it is very handy for emptying the tank. I have used it for just that purpose.
RACE ON!!!
Old Aug 29, 2005 | 10:28 PM
mash557's Avatar
mash557
And again you didn't answer the question!! What does the ECM do with the circuit. I can read a schematic and it seems that the ECM "could" do exactly as I said. None of my Helm's manuals gives any of the logic of the ECM. I have seen newer GM cars basically shutdown due to no or low oil pressure.
But we digress, the original problem is car stumbles and doesn't recover for 30-40 seconds. Most rev limiters should not take that long to recover.
drochau, I hope you get it figured out.
I'm done here. I really don't like being talked down to. CFI-EFI your sarcasm is really not needed or helpful.
Old Aug 30, 2005 | 03:36 AM
CentralCoaster
That wire is feedback to the ECM for "fuel pump low voltage" code 54. Probably one of the rarest codes, considering it has two power sources.
It's only mentioned in the code diagnostic section of the manual.
