Dana 36 woes
Old Aug 29, 2005 | 11:18 AM
calpbs's Avatar
calpbs
Default Dana 36 woes
I contacted Precision Gear and they are several months away from making 3:73 gears for the Dana 36 chunk from my 84 with a 3:07 rear. Does anyone have a source for 3:73 gears for that carrier? Will a Dana 44 fit in place of that carrier and if so how much $ and what if any modifications? I have the Energy Suspension bushings waiting on the swap. Any help would be appreciated. I am running alot of HP, over 400, maybe over 500.
Charlie
Old Aug 29, 2005 | 11:45 AM
CFI-EFI's Avatar
CFI-EFI
You can check with Jegs, Summit, Randy's, Drivetrain, and any other number of resellers to see what they carry. The Dana 44 complete differential will replace the current Dana 36. It is a bolt in. About all you will need for the conversion is the drive shaft and the "C" beam from a Dana 44 (stick) car.
RACE ON!!!
Old Aug 29, 2005 | 11:46 AM
kpforce1's Avatar
kpforce1
I know richmond makes a set of 3.73's for it. I would SERIOUSLY consider swapping for a D44 though if you have 300+ and are going to go with 3.73's. I would cost anwyere from $1000-2000 depending on the quality and if it is a roter to roter setup. Exotic muscle has some stuff listed on their web page (kinda expensive though). You will also need a modified C-Beam if you have an automatic and make sure you go through ALL of the ujoints too.
Old Aug 29, 2005 | 11:49 AM
Ramrod92's Avatar
Ramrod92
Cruise-In II Veteran
If you're going to use 3:73 gears, then you can go with the Dana 44 now or after you 36 craps out. Here are some pics of my 36 w/3:54 (which has thicker teeth than the 3:73) Here's the Dana 44 w/3:73s from DTS...
Old Aug 29, 2005 | 12:03 PM
VenkmanP's Avatar
VenkmanP
Zip carries 3.73 gears.
3.73 is generally considered to be too much for the 36 to handle though.
Old Aug 29, 2005 | 12:16 PM
kpforce1's Avatar
kpforce1
Especially with 400+ hp!
To Dana 36 woes
