Trouble Starting
Dispite my best judgement, I took my 1988 L98 TPI baby to Meineke. All I wanted them to do was run a diagnosis for what's wrong with my car. What I told them was:
Long start times (usually from cold state)
Engine sometimes dies after 1-2 Mins of driving
Black smoke comes from tailpipe, if I use the gas pedal to start the car
Rumbling noise beneath the car when I drive at slower speeds
So I take the car in at 11:00 and decide that I'll wait. At about 2:30, I finally walk up to the counter to see if they even TOUCHED it yet! They said, "Yes, and the mechanic would like to know if you could leave it for a while" Which pissed me off, because I could see my car sitting in the same parking space for well over 2 hours. So they took it, came to the conclusion that they'd need it longer, then didn't bother to tell me, KNOWING I was waiting.
You can see that I don't like them very much.
So anyways, they said nothing was wrong, but there was a service bulletin, which said all these things to do, since this is a common problem w/ the 88 'Vette. It would cost me $350 for JUST the diagnosis (gee, didn't I JUST ask for a diagnosis?) Needless to say, I didn't leave it.
So I get home, and find this thing online saying that it could be the MAF sensor realys.
It says I can replace the relays, and it may help out the problem. But here's the problem. It says that it's available as part number 14089936 from GMSPO. I'm a former Ford guy, so Iunno WTF GMSPO even stands for! I checked websites and none of them bother to tell me.
So my questions are if anyone has had these problems, which I listed above, wtf is GMSPO, and does anyone know where I can buy these relays? I found some for $14, but they say that they're for blower motor, which I'm not sure if that's another word for the Mass Airflow Sensor or if it's a compat. relay!
Thanx in advance!
~Derek
(Sorry for the long post!)
First a "12" will be flashed three times, followed by each trouble code three times, ending with another "12" three times.
Turn off the ignition, remove the paper clip from the ALDL and install the cover.
Bring the trouble codes here.
2) I found the relays at a local part store. They didn't help
3) I remembered that when I changed my spark plugs many many weeks back, I had fuel on them. So I ordered some Bosch fuel injectors from FiveOMotorsports on eBay. I hope they help!!
