l-98 and long tubes
Old Aug 30, 2005 | 12:16 PM
cmashark's Avatar
cmashark
Default l-98 and long tubes
does anybody know which long tube header and y-pipe will clear an R and D cross frame?
chris
Old Aug 30, 2005 | 01:30 PM
Trog's Avatar
Trog
I can say that TPIS clears a stock one (although I notched it anyway). And a stock X fits up just slightly tighter than an RD from what I've seen.
Old Aug 30, 2005 | 03:03 PM
AZC4Guy's Avatar
AZC4Guy
I have hooker supercomp headers on my L98 and was told by R&D that the cross frame would not get in the way.
Old Aug 30, 2005 | 04:39 PM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
The Cross Frame does not even intersect the exhaust system until well beyond the headers. You should not have a problem with any header that I know of.
Old Aug 30, 2005 | 05:07 PM
Square's Avatar
Square
When I helped a friend install TPIS headers on his 86' vert, the Brace crossed under the cat, well behind the headers.
If you use the TPIS headers/front Y-pipe, you will need to have the rear of the Front Y-pipe bent up because it hangs down too low wether you have a cross frame or not. You can't even hook up the rest of the exhaust until you have it bent.
To l-98 and long tubes
