Removing ECM for VATS disabling
He provided me with some basic instructions but it would be great for something a bit more thorough. I'm just starting to get into working on my own vehicle and I'm a bit nervous about the process. I want to be sure I'm doing it all correctly.
First things first, I need to disconnect the battery, correct? And the ECM module is inside another module underneath the driver side dashboard?
Ion told me I'm looking for a blue module which is what I need to send him.
Finally, what tools to I need? Wrench for battery, and philips screwdriver?
Hopefully I won't send him my transmission by accident.
P.S. I'm disabling the VATS because about 6 months ago it started to act hokey-- Put the key in, turn the ignition and the SECURITY light lights steady (doh!). Wait 3-4 minutes (dum-de-dum). Try again- starts.. It slowly got worse where I had to try over and over again (record was about 6 tries x 4 minutes). Now it's completely stopped working (SECURITY light always lights steady when key is tried-- no start, no crank) VATS needs to go away now.
2. The Blue Module ...sound like he is talking about the chip located in the ECM. It is blue and is like a memory chip in your computer.
3. If he is reprograming the the Chip you don't need to send him the ECM.
4. No special tools are need to to unhook ECM and removing the chip. First time it took me an hour and half to figure out how to do it. The second time about
15 minutes.
I'm being convinced that's it worth doing anyway.
btw, you mentioned that a resister pellet from Radio Shack can work as a temporary solution however how does one ascertain the resistance of the pellet on my keys?
