Broken bracket
Old Sep 1, 2005 | 12:14 PM
RWDsmoke's Avatar
RWDsmoke
Default Broken bracket
My a/c compressor bracket is broken. What is it made out of and can it be welded? Anyone got a spare for an 86? Thanks for the help.
Old Sep 1, 2005 | 01:31 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
The A/C compressor bracket on my '88 is cast Al and maybe could be welded. Your '86 has a different A/C compressor so I don't know what bracket is used; if it looks the same color and composition as the Alt bracket I would guess on Al too.
You could likely get a used one from Contemporary Corvette, link on my site.
Old Sep 1, 2005 | 02:12 PM
rons85's Avatar
rons85
Mine (85) was cracked when I bought the car - 5 years ago. The new one came from the local chevy dealer, and was fairly cheap - if memory serves it was about $40.
Old Sep 1, 2005 | 05:13 PM
tommelton's Avatar
tommelton
Aluminum as stated above, mine cracked also, had it welded at local welding shop for something like $20.
You need to be sure the rear bracket to the exhaust manifold is in place...
Tom Melton
82 CE
86 Z51 Coupe
To Broken bracket
