Question on LT4 starting and idle
Old Sep 3, 2005 | 10:02 PM
megatron's Avatar
megatron
Default Question on LT4 starting and idle
Hi everyone,
I have a 1996 LT4 with 33K miles on it that has developed a strange habit lately. It seems that since I refilled my gas tank to full (to avoid the massive increase in gas prices ), the car hesitates when I start it when it is cold.
For instance, I last drove it on Wednesday, and then drove it again tonight (Saturday). The car takes a few seconds of cranking (3-5 seconds) before it started both tonight and Wednesday. In addition, upon starting, it immediately idles at about 700 rpm instead of the usual 1500 or so upon cold start up. Does the summer weather have anything to do with this? Usually, it starts right up without any hesitation.
Once I drive it, it runs great, and starting it a few hours later causes no problem.
Also, I should mention that my A/C is currently blowing out of the top and floor only. Could this have an effect?
Anyone know what this may be?
Old Sep 4, 2005 | 02:05 AM
MetalVette's Avatar
MetalVette
Default wish
I have the same engine with no problems, I heard disconecting the batt for 24 hour then re-connecting may help.
Old Sep 4, 2005 | 05:20 AM
REDC4CORVETTE's Avatar
REDC4CORVETTE
Does the cruise control work?
Do you have a good connecton at the IAC?
Old Sep 4, 2005 | 06:43 AM
AORoads's Avatar
AORoads
St. Jude Donor '15
"In honor of jpee"
Is it poss. you switched gas stations and got a load of ethanol-mixture?
Old Sep 4, 2005 | 08:40 AM
megatron's Avatar
megatron
Could be.
Old Sep 4, 2005 | 08:41 AM
megatron's Avatar
megatron
I will check today on the cruise.
I'm ignorant, so where and what is the IAC?
Old Sep 4, 2005 | 05:34 PM
lt4red's Avatar
lt4red
The hvac blowing out the defrost is a sign of a vacuum leak. These are vacuum controled on the manual ac controls. If you have the electronic ac controls with the little temperature display then I think those vents are not controled by vacuum, but rather by a solenoid.
I would check for any vacuum leaks on the various lines snaking around the engine bay, and especially any that travel into the interior through the firewall, as one of these is surely running to your hvac controls.
A vacuum leak should cause a higher idle however, not a lower one.
The engine idleing lower could just be higher outside temperatures. The engine temp sensor will read pretty low. I think I've seen as low as 80 degrees on the digital display.
The IAC is the idle air controller. This is a valve that controls how much air your engine receives at idle to run. It is located just below the bores on your throttle body. There is a connector running to it. You can see it from the passenger side with the hood up. There is a connector also running to your tps or throttle position sensor, located right next to it on your throttle body also.
Old Sep 4, 2005 | 08:53 PM
froggy47's Avatar
froggy47
1500 is way too high for a cold start idle.
Old Sep 4, 2005 | 09:36 PM
megatron's Avatar
megatron
Cruise works as I tried it today.
Old Sep 4, 2005 | 09:37 PM
megatron's Avatar
megatron
Thanks. Think I will try cleaning the IAC.
Old Sep 20, 2005 | 02:17 PM
megatron's Avatar
megatron
Thanks to everyone for their input. I think I may have just gotten some bad gas (or at least gas my car doesn't like) from BP Amoco. I'll stick to Shell in the future as my car seems to like this brand better.
To Question on LT4 starting and idle
