LT1 oil pump drive breakage?
Old Sep 4, 2005 | 08:51 PM
500hp's Avatar
500hp
Default LT1 oil pump drive breakage?
Has anyone seen or heard of any catastrophic failures involving the LT1's plastic oil pump drive housing? I do have one of those aluminum piggyback retainers and an ARP driveshaft.
Will high RPM + HV oil pump = SNAP! ?
Old Sep 4, 2005 | 08:53 PM
cv67's Avatar
cv67
St. Jude Donor '05
Not too common on SBC's, especially with the upgrade you did. Fords usually have a problem with that. Run the pee out it!
Old Sep 5, 2005 | 08:49 AM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Who makes an aluminum drive retainer? Are you sure it's aluminum? Mine is from More Performance but it's steel. Anyhow, I also have a hardened shaft w/ the steel coupler and have never had any problems w/ high RPM usage. Flog it, man!
To LT1 oil pump drive breakage?
