Compression Test
Old Sep 5, 2005 | 06:07 PM
STL94LT1's Avatar
STL94LT1
Default Compression Test
I did a cold engine compression test on my car today. What is an acceptable variance from cylinder to cylinder?
Results:
1. 215
2. 205
3. 220
4. 200
5. 220
6. 220
7. 200
8. 200
I hurt my car on the dyno Saurday. #3 exhaust lifter was damaged, and #8 exhaust pushrod was bent/broke. Just trying to fiqure out if there is any more damage. Going to scope the cylinders tomorrow.
Anything else I should look for?
-Mike
Old Sep 5, 2005 | 06:10 PM
Pete K's Avatar
Pete K
Results:
1. 215
2. 205
3. 220
4. 200
5. 220
6. 220
7. 200
8. 200
-Mike
You are within 10%. I believe 20% or less is exceptable. A leakdown test will tell the rest of the tale.
Old Sep 5, 2005 | 06:11 PM
Pete K's Avatar
Pete K
I just noticed you did the test cold. Warm is better. Also, i always hook up a battery charger while doing the test. Kepps the voltage up so I cranks consistanyly throughout the test.
Old Sep 5, 2005 | 06:13 PM
STL94LT1's Avatar
STL94LT1
Pete, the car is tore down because of the damage I did Saturday. I'm just trying to find any other possible damage before I put it back together.
Old Sep 5, 2005 | 06:17 PM
Pete K's Avatar
Pete K
That is why I mentioned the leakdown test. If a valve is bent, even slightly, you will be able to pinpoint it. Leakdown will also reveal ring seal, gasket leakage etc.
Old Sep 5, 2005 | 06:19 PM
STL94LT1's Avatar
STL94LT1
Thanks.
Old Sep 6, 2005 | 05:37 PM
DVNCI's Avatar
DVNCI
So what happened? Why did she break?
Guess you might as well build a stroker now?
Old Sep 7, 2005 | 02:13 PM
STL94LT1's Avatar
STL94LT1
When I remove the rockers, I always reset the polylocks so that the lifters will be close during reassembly. Sunday when I reassembled the valvetrain to do the compression test. The rocker for the #8 exhaust valve was waaaay loose. My theory is: I hit the rev limiter at the dyno, and with an already loose rocker the pushrod worked it way loose, got in a bind and bent/broke.
I scoped the cylinder yesterday and doesn't appear to be any major damage to the piston, maybe not even piston/valve contact. Hope to find a leak-down gauge and test the affected cylinder in a day or two.
To Compression Test
