Lunati roller lifters
Old Sep 5, 2005 | 07:41 PM
4DJ2NJOY's Avatar
4DJ2NJOY
Default Lunati roller lifters
I'm not ready for a cam swap yet but was thinking of putting in the (Lunati roller lifters that you can change cam without pulling the intake off) part # from jegs 638-72400 when I'm doing my intake swap... Anyone know if they work good with the L-98. And would you advise using them...
Thanks, David
Old Sep 6, 2005 | 11:59 AM
2manyfuncars's Avatar
2manyfuncars
Check and see if a L-98 block can work with the Lunati lifters. A stock hydraulic roller motor has tall lifter bores and needs either maching or lifters to match.
It's worth doing some research on solid rollers - they might not be worth it unless you have a higher rpm motor (I have them myself with a superram).
Good luck
