Newbie ...1990 Advice requested
Old Sep 6, 2005 | 08:58 AM
thewedge's Avatar
thewedge
7th Gear
Default Newbie ...1990 Advice requested
Hey folks. Been lurking for a couple of weeks. I bought my Father's 1990 White Coupe TPI LT1. The car has 96k miles, new brakes, new tires, new muffler system, new rubber around all windows and inside, new battery, and a new factory transmission. Runs excellent, excellent compressions, etc. My Father drove it sparingly and gently. I have spent a lot of time on the outside and interior and was hoping to get some advice on what your top 10 list of things to do for this car would be. It is pretty much totally stock. It is a fun car and not something I am relying on for transport but I am not looking to make it a show car or anything either. Any input you can give would be appreciated... I have seen some stuff in catalogs but not sure how good the items are.. K+N, Power Now, etc...
Also, the tach does not work. When I start the car the tach goes all the way up to the top and then drops to zero and does not move. Ideas?
Wedge (Virginia)
Old Sep 6, 2005 | 09:01 AM
conv90's Avatar
conv90
First... welcome!
second you should see if you purchased a 90 or a 92 because a 90 is not a LT1 it's a L98.
-Beppe-
Old Sep 6, 2005 | 09:05 AM
thewedge's Avatar
thewedge
7th Gear
Good point.. The title says 1990 so it is probably not the LT1. I am pretty green with Vette knowledge.
Old Sep 6, 2005 | 10:15 AM
Rick86's Avatar
Rick86
Welcome to the forum. First on your list of things to do will be verify the car is running at its best. You'll want to run a scan on your car to get a good base line. There are a few free mods that seem to work pretty well, but you have to first make sure car is running at its best. When I changed my spark plug wires I noticed my car idled better and accelerated much smoother. Good Luck and Congratulations on the Vette.
Old Sep 6, 2005 | 11:09 AM
GordoC4's Avatar
GordoC4
Sounds like your tach filter needs replacement. Follow the tach wire from the distributor and it will lead you to the filter.
It's black,cylindrical shape and about 2 inches long
good luck
Old Sep 6, 2005 | 12:38 PM
thewedge's Avatar
thewedge
7th Gear
I will check it out when I get home from work. I checked online at lunch and called Ecklers and CA and neither had a replacement part. Is it something cleanable or do I have to hunt down a replacement?
Old Sep 6, 2005 | 01:06 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
Welcome to the Forum and congrats on your new '90 Vette.
Follow the wire from the HEI dist to the capacitor like item bolted to the top of the bell housing to locate the tach filter. If the wires are in tact, try Contemporary Corvette (link on my site) for a replacement.
The most important item is to come with a plan before starting major mods; heads, cam & intake need to all work together for best results. Some minor mods that will add maybe 25-30chp chp are:
-toss the frisbee from the watere pump pulley
-a 160deg T-stat & fan switch
-cut lid with K&N or a TPIS ram air setup
-cut back stock style AC Delco spark plugs
-TB coolant bypass mod
-an AFPR
Your L98 will respond very well to exhaust mods, though they can be pricy. The best setup is true duals with dual cats, if local regs allow.
Your L98 has the SD intake so major mods will likely require mods to the EPROM. There are people on the Forum to help in this area.
Enjoy your Vette and save the wave.
Old Sep 6, 2005 | 01:16 PM
thewedge's Avatar
thewedge
7th Gear
I have been looking into this online also. Let me ask a dumb question...is this actually a "Filter" or is it an electronic device? I seem to have found info online that say a tech filter is a compressor of sorts that limits spikes and other electronics in the Tach signal. I am just trying to get some info as to what I am looking at. That you all very mich for the info! I'll post some pics of the car later...
Old Sep 6, 2005 | 01:45 PM
65Z01's Avatar
65Z01
It is an electronic filter to take out spikes in the tach signal; it should be an Al cylinder about the dia of your finger and maybe 1-2" long with a wire from either end.
Old Sep 6, 2005 | 02:11 PM
thewedge's Avatar
thewedge
7th Gear
Is this something that has to be there? What if I just clipped it out of the loop? If it has to be there, can I clip it out to test and see that the problem is in that unit?
Wedge
P.S. Pics.... After using a cleaner...wax.
http://www.chasingrhinos.com/vette/v1.jpg
http://www.chasingrhinos.com/vette/v2.jpg
http://www.chasingrhinos.com/vette/v3.jpg
http://www.chasingrhinos.com/vette/v4.jpg
http://www.chasingrhinos.com/vette/v5.jpg
Old Sep 6, 2005 | 02:26 PM
65Z01's Avatar
65Z01
Electrically it looks like a low-pass filter to remove voltage spikes from the Tach signal to the display; I'm not sure if those spikes would harm the display.
Old Sep 7, 2005 | 08:48 AM
thewedge's Avatar
thewedge
7th Gear
OK...this was a mess last night. On the side of the distributor there are two wires leasding out of a harness. The left side said Tach and had a white wire. It went under and dove down in the darkness next to the firewall. Best I could tell it went into a cable harness that came back up to the battery area and attached to the positive. This did not make much sense to me but that is what it looked like. It did run through a small cylindrical item that may or may not be this filter...it looked nothing like pics I could find on the internet of the filter. It was an inline thing right before the wire that was attached to the positive so it would have had no ground wire.
Ideas? or should I punt?
Wedge
To Newbie ...1990 Advice requested
