What size hole for knock sensor/coolant temp sensor?
Old Sep 6, 2005 | 10:44 PM
flyersfan1088's Avatar
flyersfan1088
From: What did the 5 fingers say to the face? SLAP!!
Default What size hole for knock sensor/coolant temp sensor?
I'm having my heads drilled and tapped for the coolant temp sensor and knock sensor. Are they both 3/8"? I trust the head shop to do it right, I just want to make sure there's nothing unusual that I need to tell them first before they do the surgery. Thanks
Old Sep 6, 2005 | 10:49 PM
Pete K's Avatar
Pete K
I "think" that they are 3/8 npt. Give 1 of the sensors to the guy bangin the hole, just to be sure.
Old Sep 7, 2005 | 12:02 AM
Corvette Kid's Avatar
Corvette Kid
Large Impressive Member
From: Good health is merely the slowest possible rate at which one can die
St. Jude Donor '04-'05-'06-'07
Knock sensor in the head?
Old Sep 7, 2005 | 12:14 AM
flyersfan1088
Sure looks like it. What should be in the drivers side head in an '86?
Old Sep 7, 2005 | 12:59 AM
goldeneye_vet's Avatar
goldeneye_vet
temp sensor?
Old Sep 7, 2005 | 01:53 AM
USAsOnlyWay's Avatar
USAsOnlyWay
Its not the knock sensor, though the driver's side head does have a sensor with the same type connector as a knock sensor.
The passenger side is the coolant temp "switch", I am not sure what the other sensor is right now, nor do I know the size.
As suggested above give the guy the piece to go in, I am pretty sure it is 3/8 npt too though.
Old Sep 7, 2005 | 06:30 AM
flyersfan1088
It seemed strange to have a knock sensor in a head, but you're right. The connector looks exactly like the connector for a KS.
Old Sep 7, 2005 | 08:01 AM
FoolCrzy's Avatar
FoolCrzy
I "think" that's the fan switch....
Old Sep 7, 2005 | 08:49 AM
DRAKEFAMILY2's Avatar
DRAKEFAMILY2
The knock sensor on my 84 is in the side of the block below the passenger side head.
Old Sep 7, 2005 | 09:03 AM
rick lambert's Avatar
rick lambert
Knock sensor is in the block-fan switch and coolant temp sensor in the heads.
Old Sep 7, 2005 | 10:15 AM
CFI-EFI's Avatar
CFI-EFI
For 1986, the left head, between the #1 and #3 spark plugs, takes the axillary fan switch. The right head, in the same hole, which is between the #6 and #8 spark plugs, when you swap sides, takes the sending unit for the instrument panel temperature gauge. The knock sensor goes into the block, water drain hole, just above the pan rail, on the right side of the engine, just forward of the starter.
RACE ON!!!
To What size hole for knock sensor/coolant temp sensor?
