8 rib project finished
Old Sep 7, 2005 | 02:08 AM
Mo_Bandy's Avatar
Mo_Bandy
Default 8 rib project finished
Hi Guys,
I finally finished installing the Blowerworks 8 rib system. With a lot of travel it has taken a while... But the results are worth the wait.
In conjuction with that, I moved my MSD under the drivers seat, remounted the coil on the front cross member, relocated the Gaseous injection punp in the drivers side headlight cove, LT4 extreme roller chain. Mainly just trying to get a cleaner look.
The first time out I was pulling 11.5 pounds of boost, I had to pull out of it as I was running lean... So I'm still dialing in the fuel.
If you're interested in seeing pictures as the project progressed you can visit my website www.ndneyes.com/mo under "Mo's projects"
regards,
Mo
Old Sep 7, 2005 | 06:36 PM
bacardioil's Avatar
bacardioil
hi mo
glad to see your up and running, just tune it up and let it fly.
regards
gene
Old Sep 7, 2005 | 10:36 PM
zelement's Avatar
zelement
Mo,
glad to hear you got it up and running!
Are you running a WB? How lean did it get?
Old Sep 8, 2005 | 08:56 PM
DRAKEFAMILY2's Avatar
DRAKEFAMILY2
Nice site, great music.
Old Sep 9, 2005 | 02:07 AM
Mo_Bandy's Avatar
Mo_Bandy
Originally Posted by zelement
Mo,
hi Z it wasnt that "bad" I was still at like 13.8 I needed to set the fuel up a few more pounds... no damage or anything... "funny thing is there was no knock
Mo
Old Sep 9, 2005 | 02:40 AM
zelement's Avatar
zelement
11.5 psi and 13.8:1 with no knock? you are lucky. did you have the alky spraying?
Old Sep 10, 2005 | 01:08 AM
Mo_Bandy's Avatar
Mo_Bandy
Yeah, I did,,,
I'm sure that helped! I'm running 15 GPH 50/50 mix
Mo
Old Sep 11, 2005 | 01:03 AM
qwiketz's Avatar
qwiketz
saw the setup today. The belt tension is a million times better than the stock vortech setup. Finish is top notch.
Old Sep 12, 2005 | 05:28 PM
Raysur's Avatar
Raysur
Wayne,
That is an awesome setup! You seriously did a great job with your supercharger. I took this term off at school so if you need help or want to meet up let me know.
Old Sep 12, 2005 | 05:58 PM
Mo_Bandy's Avatar
Mo_Bandy
Hey Raysur,
Thank you!
Cool would love to get together...
Mo
Old Sep 13, 2005 | 01:02 AM
qwiketz's Avatar
qwiketz
another so cal f/i c4'er. We should all meet up at the track sometime soon or cruise out to somewhere in the middle and talk some shop.
Old Sep 15, 2005 | 02:02 AM
Mo_Bandy's Avatar
Mo_Bandy
Raysur and you should get together qwiketz... your fairly close in age...
I know they used to have car meets at fudruckers in pasadena, not sure if that is still happening or not...
Mo
Old Sep 15, 2005 | 10:02 AM
cjg454ss's Avatar
cjg454ss
Originally Posted by Mo_Bandy
Hi Guys,
regards,
Mo
is this on a stock short block?
Old Sep 15, 2005 | 12:44 PM
Mo_Bandy's Avatar
Mo_Bandy
Yes it's a stock short block...
To 8 rib project finished
