1994 6-speed clutch/trans problem
Quick background:
The car is basically stock, 135k miles. Only "mods" are K&N filter and !CAGS. I parked it for about a week and a half. Prior to that it drove fine, shifted normally, no strange noises, etc. I got in it yesterday to go to work and all seemed normal at first. Engine running, clutch was engaged (pedal up), trans in neutral. I pushed in the clutch, shifted to reverse and began to back out of the garage. I only made it a short distance and it began to make a whining noise (may not be best description). I pushed the clutch in and it immediately stopped. I tryed again, same results, forward and reverse. The sound is pretty loud and seems to be constant in volume. I haven't driven the car any good distance since, so I havent had the clutch completely engaged yet. It starts when the pedal is about 3/4 of the way up, when it just starts to grab I suppose.
I did some searching on the forum and I'm hoping it is a pilot or thowout bearing or the DM flywheel or a combination there of. To my knowledge the flywheel is original, and from what I read here, should be close to done @ 135k. I am the third owner of the car, and the guy I bought it from did not do any clutch work to it. I believe he bought it at 78k. He had no knowledge of any major work performed by the first owner either. I had to replace the opti shortly after I bought it @ 125k. The clutch/pressure plate/bearings may be original as well (possible?). All of the coolant hoses even have 1994 stamped on them. Anyway, I'm hesitant (in denial?) to think it is internal to the trans because the noise stops so quickly when the pedal is pushed in, and I've been able to go forward in 1st gear and the noise not occur every time.
Any insight and is greatly appreciated. If I left something out that will help diagnose, please ask.
Thanks in advance!
Does it make the noise in gear and when you are moving? Or only in neutral? Is it all gears?
First thing I would do is check for something laying against the driveshaft. While you are under there check the fluid level in the transmission. It's unlikely something would break just sitting around so it's probably something simple.
Do you notice any clutch slippage?
I'm at a loss. What are the symptoms of low hydraulic fluid? :o Something I forgot to mention is that the reservoir was a bit low yesterday, so I added fluid but it didnt seem to help at the time as the noise was still present. Then today the problem seems to have disappeared.
Ideas?
I have already ordered a new DM flywheel and stock replacement clutch kit from Tom @ Carolina Clutch. If I drive the car again this evening and it does OK, should I send the parts back? Chalk one up to gremlins or what??
Thanks again.
Thanks again.
I haven't checked the tranny fluid but was told it was replaced a few thousand miles ago. Clutch fluid is the correct level.
Dave
