how hard to remove front bumper??
Old Sep 9, 2005 | 02:47 PM
DieL's Avatar
DieL
Default how hard to remove front bumper??
Seems easy.. popped the hood and can see all the little bolts holding it in place along the hood and some on the sides.. is there Any bolts i should avoid removing? i read somewhere that some are for alignment.. i dont want to mess it up. Im very mechanically inclined just thought id post to see if theres a heads up i need before i get myself in to something !
i really just need a shop manual. !
Old Sep 9, 2005 | 03:30 PM
Corvette55's Avatar
Corvette55
Remove the lights and all the little bolts and it comes right off.
Old Sep 9, 2005 | 04:38 PM
sraft's Avatar
sraft
It's not as hard as you think. On my '94 I can get the bumper off in ~1/2 hour, although I'll admit the first time I went slow & carefull and probably took 1-1/2 hour. In all, there are ~20 fasteners total. It helps to have a second pair of hands when you're ready to pull it off/put it on so that you don't scratch the finish.
Old Sep 9, 2005 | 07:36 PM
DieL's Avatar
DieL
sweet.. i was actually quite scared to check the responses... some other thread a while back had me worried a little.
thanks !!
Old Sep 9, 2005 | 07:59 PM
redbullapril23's Avatar
redbullapril23
just make sure you line it up correctly when you put it back on
Old Sep 9, 2005 | 08:39 PM
DieL's Avatar
DieL
thanks !!
Old Sep 10, 2005 | 01:51 AM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Real easy. Took me less than an hour my first try. Those ratcheting wrenches will come in handy, or at least protect the front of the hood with something, when you loosen the top retainer bolts, you'll be close to scratching the hood with your wrench.
When you get all the bolts off, lift the top edge over the steel, and pull the bottom down to get it loose. The helm book was handy on this.
I don't see what the big deal is with lining it up, it's determined by the steel which isn't removed. But then again, I haven't remounted mine.
Old Sep 11, 2005 | 01:40 PM
DieL's Avatar
DieL
thanks for the tips. my real concern was lining it up but it doesnt seem to be difficult.
To how hard to remove front bumper??
