Hooker shorties
Old Sep 10, 2005 | 03:59 PM
RFDrpm's Avatar
RFDrpm
Default Hooker shorties
Im doing the install on my hooker shorties. '92 coupe, P engine LT1. And the EGR Valve on the passenger side dosent match up with the new hooker.
On the drivers side is a rubber hose and will move, but the one on the pass side is solid metal.
Anyone been through this?
What to do?????
Old Sep 10, 2005 | 05:18 PM
STL94LT1's Avatar
STL94LT1
Take the air tube loose frome the rear of the head, and push it toward the firewall.
Old Sep 10, 2005 | 07:34 PM
Randexter's Avatar
Randexter
Im not sure if you can get the egr tyube to fit up without cutting and rewelding it back together. I installed my shorties about 3 weeks ago and I had to cut out about 3/4 of an inch to get the pipe to fit up. actualy as I remember it its in the instructions that you have to cut and reweld the pipe. its not to big of pain just cut it and mark it so the fitting still points in the right direction.
Old Sep 10, 2005 | 09:54 PM
Strick's Avatar
Strick
Yep, take the AIR pipe to a precisson welder and have him cut out 1" from the pipe and reweld it back up maintaining the same alignment. Also, with a little grinding, you can use all your brackets off the A/C and alt mountings. One other tip, I used 1" header bolts with allen socket heads made out of S/S. Much easier to torque.
Old Sep 10, 2005 | 11:08 PM
RFDrpm's Avatar
RFDrpm
So after the install i need to go ahead and take it to a welder. OK. Is it going to hurt it to drive with this unattached, or should I have it towed?
Old Sep 10, 2005 | 11:51 PM
STL94LT1's Avatar
STL94LT1
Don't waste your money on the welder. As I said earlier, unbolt the airtube from the back of the header, and push it toward the firewall. Then screw the airtube to the header.
Old Sep 11, 2005 | 02:51 AM
RFDrpm's Avatar
RFDrpm
Ill give that a shot in the am. Ill let you know how it works out.
Old Sep 15, 2005 | 12:15 PM
RFDrpm's Avatar
RFDrpm
Thanks STL94LT1, took some prying with the crowbar but it matches up fine now. Saved me $40.
Old Sep 15, 2005 | 05:49 PM
gslotman's Avatar
gslotman
How about some dyno numbers posted if your going to do so. Lots of talk on the shorties here at the forum. Some DIS them and others claim their fine (7-9 RWHP & TQ) for what they offer to those of us in SMOG burdened states....but numbers help us all.
Old Sep 15, 2005 | 08:52 PM
~db~'s Avatar
~db~
I'm interested in the dyno numbers as well. If no numbers yet then whats you 'seat of the pants' opinion on them?? Sound better or different??
Old Sep 16, 2005 | 01:33 PM
Strick's Avatar
Strick
Glad you got it connected. I'm just not a fan of that kind of maintenance/fabrication. Usually you can tell if it's been treated like that. Anyway, glad you didn't kink it or worse, break it.
Old Sep 16, 2005 | 01:48 PM
RFDrpm's Avatar
RFDrpm
I have no baseline dyno to go from, but plan on putting it on the dyno after all is finished. I usally use the "butt o meter", I find it gives the best refrence when measuring increase in power.
To Hooker shorties
