Superramed engine with SC
Old Sep 11, 2005 | 06:22 AM
Sliding's Avatar
Sliding
Default Superramed engine with SC
I must be going really crazy. I'm thinking of supercharger and haven't
even received my superram. What can I say, I like to plan ahead.
My question is ( I've allready asked and I know superram is SC friendly)
will SC work with superram and 219 cam or is blower cam necessary?
Does anybody here have this combo?
Old Sep 12, 2005 | 11:44 AM
crazyturbo's Avatar
crazyturbo
Hellow Sliding, Cam selection is very important to maximum power. The cam should be chosen on the following criteria, engine cid, CR, intended use, cylinder head flow numbers, idle vacuum, valve train stiffness and quality, maximum rpm, gear ratio, intended stall if auto trans,
Forced induction, and kind of fuel.
If you have time please fill in the blanks above and I will try to pick the right cam for you
Shane………….
