clutch master cylinder ??
Old Sep 11, 2005 | 10:54 PM
ZD1's Avatar
ZD1
Default clutch master cylinder ??
Couple of questions for my 91'
What is the thickness of the spacer between the master cylinder and the firewall? I'll need to make one if I can't find one used....
What is the routing of the hyd clutch fluid line? Under/Over brake booster? Around exhaust? Between exh and block? Bolted to the oil pan in any way?
