best place to buy diff gaskets?
Old Sep 13, 2005 | 10:50 AM
GunShow's Avatar
GunShow
Default best place to buy diff gaskets?
Other than the dealership, are there any recommended places to buy diff gaskets from?
Old Sep 13, 2005 | 11:37 AM
CFI-EFI's Avatar
CFI-EFI
Good luck at the dealership. Dana never made one, so consequently the dealership has no source. If you really want one, you'll have to make it yourself.
RACE ON!!!
Old Sep 13, 2005 | 12:51 PM
GunShow's Avatar
GunShow
Great, maybe I will just keep replacing the fluid as it leaks out.
Old Sep 13, 2005 | 01:08 PM
Pete K's Avatar
Pete K
RTV is used to seal the diff.
Old Sep 13, 2005 | 02:18 PM
PLRX's Avatar
PLRX
Co-winner 2020 C4 of the Year - Modified
2017 C4 of Year
2016 C7 of Year Finalist
St. Jude Donor '09 thru '20
Make your own gasket. Buy it at any auto parts. get a razor and a hole puncher...
Old Sep 13, 2005 | 03:01 PM
aboatguy's Avatar
aboatguy
What you want is the RIGHT STUFF from Permatex.
Follow the simple directions and you'll have a leak free (from the mating surfaces) rear. If only the three oil seals were so easy.
Mike
Old Sep 13, 2005 | 03:20 PM
GunShow's Avatar
GunShow
So the RIGHT STUFF from Permatex, is the best eh?
Did you guys use the air compressor hose and the oil bottle technique to fill the oil, or is it actually possible to powr a bottle under there?
Old Sep 13, 2005 | 04:05 PM
Tom Piper's Avatar
Tom Piper
I had a problem with sealing when I had synthetic gear oil -- and the sealing was done correctly, but not with the RIGHT STUFF.
Since I took it apart and resealed it, I no longer use synthetic gear oil and I havn't had any problems.
Tom Piper
Old Sep 13, 2005 | 11:02 PM
CentralCoaster's Avatar
CentralCoaster
From: San Diego , CA Double Yellow DirtBags 1985..Z51..6-speed
Invest in $10 fluid pump from the parts store. You can even use it to pump fluid out of the diff if you're creative. It threads onto the quart bottles.
Old Sep 14, 2005 | 01:00 AM
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
Yeah the Right Stuff is worth every penny.Its more expensive than tradtional RTV and sealers but I have yet to see one that is better than this.
Its also great to use for your intake manifold as well.
Old Sep 14, 2005 | 09:50 AM
aboatguy's Avatar
aboatguy
Unlike Toms experience I have synthetic in my rear and no leaks. However, when I performed my D44 install I replaced all three oil seals and used the "RIGHT STUFF"
Good luck!
Mike
To best place to buy diff gaskets?
