Ride control problem
Old Sep 13, 2005 | 02:09 PM
Caleb56's Avatar
Caleb56
Default Ride control problem
Service ride control light stays on what could be the problem?
Old Sep 13, 2005 | 03:13 PM
Yellow95's Avatar
Yellow95
Usually a shock or shock actuator is broken. You need to pull the codes to figure out which corner has the problem.
The shock is about $200, the actuator is about $300. If its not a shock or actuator, it could be a lot of money.
The replacement of the parts is pretty easy.
Old Sep 14, 2005 | 04:50 AM
Captainz's Avatar
Captainz
Caleb56 you may want to check out this current thread in the c4 general section.
http://forums.corvetteforum.com/show...98&forum_id=34
c4cruisers response to this same question is well written there.
To Ride control problem
