Injectors for 396
which injectors would you recommend for a 396, 6500rpm maximum?
regards
I have been involved with 434 CI motors running the best intake/head combo available for a 23* head motor that successfully run weekend after weekend 24# injectors (same injectors going now for 4+ years) in the low 11s to very bottom 10s. This is on a 85 MAF ECM.
I personally have run run 10.3s in 85 degree weather this year turning 7k rpm with 30# injectors and feel they are overkill. I can run as low as 10.5 A/F ratios if I want. My setup should dip into the 10.0s or maybe if I am lucky 9.9s if the weather gets real good.
I have tuned 415CI motors with 30# injectors that runs 9.9s as of lately with a stock 90 ECM.
We have run 24# injectors on 2 very successful and well respected 406 CI motors also sporting very good head/intakes that ran 10.9s and 11.0s.
There are several other 406 combos out there modeled after ours running low 11s, and winning countless rounds of eliminations (ralph)
There is 85vet's 383, and also corvette0096s, Beachbums 383s all running VERY low 11s weekend after weekend with 24# injectors.
There are tons of other examples of cars running less or equal to 30# injectors that put out VERY good numbers and run reliably year after year with these injectors.
So I guess the questions is what do you want to believe?
Real world examples as above that have PROVEN results or guestimates of what supposedly should work.
One thing is for sure with asking a question like this, especially on a forum board, you will NOT get a definative answer - so you have to choose which answers are best supported with the results you want. Above are some examples of some of the best running cars that pop to the top of my head off this board.
I realize that your trying to make the best decision for your application and with that said that is why I am trying to give you information with results that you can effectively compare to. The above setups are all VERY strong running and I am sure there are many others out there, but these motors above all fall into and exceed what your looking to built, so I don't see any reason your motor would not fall into the same area.
If you would like to discuss this more offline I would be happy to tell you more about some of the other findings we have found that go along with this topic.
Good luck in your research....
I would say at least at 30 and probally a 36. I've seen 30's go static at 430rwhp and 36's get you up to above 480 pretty easy on a NA car.
30's get you pretty damn far for most NA applications. 42's get you to about 500rwhp in a blown car.
again I question how a bunch of us can do it weekend after weekend with TONS more motor running very good times with the same stuff with WB02s and some of the best datalogging equipment.
I make this recommendation since you said you are not using a tuner. If you were using a tuner I would get what he recommends. In my case I have stock injectors and im running out of fuel in the higher rpms. My tuner, Alvin, at www.pcmforless.com recommends that I go to 30's which I will do. With your engine I would not be surprised to see a need for 36 or so based on what I have seen posted here by reputable tuners.
I won't do this car though. Its too extreme for mail order tuning. I will be happy to do it if he can get feedback like TTS Datmaster datalogs or dyno sheets.
When you get wild like this its harder to directly match up your car with someone elses for a mail order tune. I don't want to waste his money or my time.
If he gets a chip burner and a datalogging cable and one of our 'over the net' tuning packages we can really fine tune her in.
Hi Alvin!!
thats not the problem...i have TTS Datamaster, a Eprom burner, cables, WBO2, Tunercat...
i think, when the time have come, we should get in contact, if you want!
regards
