Drive Shaft U-Joints Changed??
Old Sep 15, 2005 | 12:26 PM
BIGJIM13's Avatar
BIGJIM13
Default Drive Shaft U-Joints Changed??
Hi
I have a 93 Ruby Red and there is a clank sometimes when I shift into reverse. I have changed the u-joints on the half shafts, but I suspect the ones on the drive shaft. Has anyone changed the drive shaft u-joints? is it a big deal?
Old Sep 15, 2005 | 12:54 PM
aboatguy's Avatar
aboatguy
I have. It is not a big deal but, it is tight, due to Cbeam and tunnel clearance issues. However, for me it was easier than the half shaft u-joints.
MIke
Old Sep 15, 2005 | 02:01 PM
BIGJIM13's Avatar
BIGJIM13
Mike
did you have to drop the exhaust??
Old Sep 15, 2005 | 02:12 PM
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
Yes drop the exhaust for the driveshaft
For the halfshafts:
http://personal.tmlp.com/scorp/vette/images/ujoints/
Old Sep 15, 2005 | 03:01 PM
aboatguy's Avatar
aboatguy
For the halfshafts:
Yep, I have a Vert with an A4 and it seems like I have to drop the Xframe and exhaust for everything but an oil change
Great link however, I don't pull the camber bolt when I pull my half shafts I remove the bolts from the bottom of the batwing instead, so that I don't screw with the rear end alignment.
Mike
To Drive Shaft U-Joints Changed??
