90 Procharger Setup
Had a few questions. I come from a small displacement turbo world, I find things are a bit different here.
The stock FPR was leaking fuel out of the vacuum nipple. I replaced the FPR seal/spring/piston. Is this a common issue?
Also, the stock FPR had the vacuum line disconnected. Wouldn't this have to be connected to reduce fuel pressure in vacuum? Also, does the stock FPR not pressurize from a boost signal? (eliminating the need for the ATI FMU?)
Also, in the ATI manual I have, it basically says to wire the fans on all the time. The previous owner decided to wire a manual switch. Leaving the switch on at all times keeps the water temp gauge at about 135 (just under the first notch) Is this the intended operating temperature?
Also, I'm getting some surge under extremely light loads. Ie. If I rev the engine and hold it at 2k, it oscillates. Or if I need to drive at 15MPH, the car surges consistantly. Is this because of the drag of a supercharger? (didn't really have the same type of surge with turbos)
What type of pistons are on the L98 (1990 vette)? If properly tuned how much boost could she take?
Apparently I have a 7lb pulley on, but realistically see 5lbs at WOT, is this normal?
Thanx for any thoughts! Still adapting to the vetter world, but its a lot of fun having all this torque on tap!
Aaron
If I click off the fan and its 75ish outside, the temp will sit right at 140. (cruising at 75mph)
Thanx again!
Thanx again!
Aaron
Unfortunately, the oil temp sensor is not working at all.
Also, on a completely different note. Does the supercharger make a gear mesh sound at low RPMs? (1k-1.5k) When I accelerate slowly in 1st gear or travel slowly at that RPM range, it sounds like a gear mesh (almost like a grinding sound, but smoother and not as loud). I didn't know if this was normal, or maybe I'm getting some exhaust rubbing due to low RPM resonance. (or something else entirely?)
