86 L98 Build Up Review Request
Old Sep 16, 2005 | 08:57 PM
ramiles's Avatar
ramiles
Default 86 L98 Build Up Review Request
Am original owner on an 86 L98 (iron heads) with 50K miles - have some time and a little money and would like to build up the motor. Looking mostly for torque 1500-5000rpm. Was thinking that the Vortec heads and manifold, cam and headers, mated up to my original TPI reprogrammed would be the right balance of performance and cost. Went to a good place here in San Antonio and they asked me to consider a crate motor and the following options and prices:
Vortec TPI Crate Motor $4,199.00
Large Runners $449.95
52m Throttle Body $399.95
Adjustable MAF Sensor $496.95
30 lb injectors $299.95
Stainless Stell CatBack $699.95
Hooker Headers $810.95
Engine Labor 25 hours $1,875.00
Exhaust Labor TBD
Coputer Reprogramming $250.00
Dyno Tune $600.00
Total $10,081.70
Appreciate your thoughts about how this would achieve my original build up objective and what parts and prices I should question. Thanks
Old Sep 16, 2005 | 09:38 PM
Vic'89's Avatar
Vic'89
I recommend that you forget the crate motor. You have only 50K miles on your car, these L98's can go 200K on the bottom end.
Go with a nice exhaust setup to include Hooker headers and a cat back system. Next add AFR heads and a Lingenfelter cam.
Lastly, install a Superram intake.
You do not need 30 lbs fuel injectors. Yuor stock 22 lbs injectors will be fine.
Parts should run you about 5K for what I listed above.
Vic
Old Sep 16, 2005 | 09:42 PM
vader86's Avatar
vader86
I wouldnt go with a Vortec setup, go with some nice aluminum heads. If you want to save money, try to find some 88-91 Corvette heads, casting '113. They should be available on ebay or perhaps in the for sale section here, just start looking.
Do NOT buy the adjustable MAF, keep the original.
30lb injectors will likely be way too much, especially if its staying as a 350. 24lb should be plenty.
You could find the headers cheaper on ebay, and you can buy them new on Summit for less than that, though with shipping it may come out the same.
52mm TB is useless for you on a 350.
Complete catbacks will run roughly that amount from anywhere.
You can find the runners cheaper than that as well.
I would not pay that money for programming and a dynotune, thats outrageous to me.
You should run a search in the archives, look for Heads, cam, and intake setups: like AFR, TFS heads, Superram or Miniram intake, Hooker and TPiS headers, etc.
You will find more than you can read.
Old Sep 17, 2005 | 02:36 AM
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
I had my 86 L98 with stock heads rebuilt for around 1500 bucks.I raised the compression and added a crane cam and it made the car run really strong.I used the stock intake,tubes and TB and had no problems with it.
If you want to increase torque,dont bother with a larger TB,runners or etc.Keep the intake set up stock and maybe change the engine to a 383 size with a decent cam and some head work.Youll make so much torque like this youll be roasting the tires into 4 gear.Especially for your powerband you want it to work at.If you want to doa 383,and change the intake and runners to a larger size,thats fine.It may help the power band some more.But 10K for an engine you quoted is a rip off.
If I spent 10K I would expect the package to exceed 400 HP and 450 ft lbs of torque.
Old Sep 17, 2005 | 02:39 AM
88BlackZ-51's Avatar
88BlackZ-51
Exhaust Labor TBD
Dyno Tune $600.00
Total $10,081.70
re-think that idea, $10000 for a motor like that is crazy.
Old Sep 17, 2005 | 02:57 AM
hippy's Avatar
hippy
Keep your short block, it only has 50k on it. Use Mobil1 and keep the revs below 6,000.
Trickflow heads 1250, P.S. their junk I had to say it.
Used intake, Big tube runners, 600.
Headers, I use TPiS, no more learning curve to install. 750.
Cat back, 300
HotCam 180
Pulleys, 150
1.6 rockers 300
Hi Flow cat 150
Alvin chip 150
So far that is 3830 a damn far cry from 10 large.
Not sure if you are an auto but if so,
PI Tq conv 750
Shift kit 100
Boost valves 75
Now you are at 4755
Please send me the balance left over from the 10grand to my bank acct.
This setup will be a very fun car to drive.
Seriously, I do have a bigmouth and Large tube runner (NOT HEADERS) the intake TPiS runners for sale.
Old Sep 17, 2005 | 03:38 AM
AZC4Guy's Avatar
AZC4Guy
rebuild your block... you can build a better motor for much less money than you'd spend on a crate motor.
Old Sep 17, 2005 | 09:05 AM
ramiles's Avatar
ramiles
Thanks for this feedback. It was the kind of experienced based replies I was looking for.
Was surprised that no one said anything positive about the Vortec approach - that that for the L98 and a torque objective those heads would have gotten a positive.
Old Sep 17, 2005 | 10:00 AM
cv67's Avatar
cv67
St. Jude Donor '05
The 113 head isn't bad, but its outdated in comparison. I'd keep the stock block;if it needs a timing chain the time to replace it would be now as you may want to stick a small cam in, maybe a ZZ4, Lingenfelter 211, Comp XE262, etc.
Vortec heads and intake, AS&M runners
48 mm (stock) TB-You don't need any bigger
22-24 lb injectors
LT's if you can, a good 2.5" exhaust, hi-flo cat
Don't underestimate the Vortec head, they make great torque for the street and last indefinitely. You'll have a strong runner on your hands for a LOT less than 10k.
Old Sep 17, 2005 | 10:12 AM
cplonner's Avatar
cplonner
Exhaust Labor TBD
Dyno Tune $600.00
Total $10,081.70
If you are wondering what that set up is like I have just about exactly that on my 86' without the 52mm tb and i have 24 pound injectors. Exerything is great but with my vortec heads, I cannot have a cam lift of over .478. There is a set of vortec heads you can buy with a max lift of .550( I have seen them in summit). I wish I new they existed when i was buying my heads. I havent dynoed the car yet but it puts out some nice power. My guess is about 290-300 rwhp and close to maybe 360-370 lbs of torque. You can get way more than that if you get a bigger cam than me. My lift was .474 Intake and exhaust. That price they gave you is too much. I paid $7000 problably all said and done. IF you want to know more ill answer any questions, just private message me!
Old Sep 17, 2005 | 12:41 PM
flatlne's Avatar
flatlne
Cat back, 300
HotCam 180
Pulleys, 150
1.6 rockers 300
Hi Flow cat 150
Alvin chip 150
PI Tq conv 750
Shift kit 100
Boost valves 75
Now you are at 4755
Make Hippy a deal on the intake he does not need it any more.www.thirdgen.org there is a zz9 cam out there cheap,I have a set of 1.5 rockers comp mags.I have set of 1990 c4 heads 25000miles buy them have them ported.
Old Sep 17, 2005 | 02:18 PM
ramiles's Avatar
ramiles
I'll look up the articles on sale - thanks. Didn't consider the automatic (which I do have). What is the "PI" brand and what is the skinny on "boost valves"?
To 86 L98 Build Up Review Request
