85 Ignition Timing
Old Sep 16, 2005 | 09:58 PM
selkirk24's Avatar
selkirk24
Default 85 Ignition Timing
Have a strange problem, maybe someone can help me out here. I set my base timing to 6 degrees as per factory specs, unplugging the brown wire when I do it.
Then when I hook the wire back up again, the timing is sitting around 18 degrees at idle. If I rev up the motor a bit, it ends up going way past the degree wheel marking.
From what I can see, this is way too much advance. What controls the advance, the ecm or that little box, think it is called spark control module, or something like that.
Old Sep 16, 2005 | 10:04 PM
CFI-EFI's Avatar
CFI-EFI
You don't have a problem. That is normal. It is THE reason you disconnect the EST wire when you set the timing.
RACE ON!!!
Old Sep 16, 2005 | 11:44 PM
vader86's Avatar
vader86
ECM advances it after you set the base, its normal.
I set it at 8* instead of 6*.
To 85 Ignition Timing
