'95 Radiator Removal
Old Sep 17, 2005 | 02:44 PM
cajuncruiser's Avatar
cajuncruiser
3rd Gear
Default '95 Radiator Removal
Is there any easy way to remove the six screws in the front connecting the upper shroud to the lower shroud?
Old Sep 17, 2005 | 03:14 PM
Gooseit's Avatar
Gooseit
No! there is no easy way that I know of. I have a 95 and had to replace the radiator last year.But once you finally get them out, turn the clips around and put the screws in fron the other side when putting it all back together. You can get to them from under the car were the airs going in. Good luck
Goose
Old Sep 17, 2005 | 03:17 PM
cajuncruiser
3rd Gear
I appreciate the tip! What did you use to get the screws off?
Old Sep 17, 2005 | 03:26 PM
LT-4 CE's Avatar
LT-4 CE
From: Everyday you must choose between the pain of discipline and the pain of regret. Fredericktown, OH
I, too, found it easier from underneath. I was also replacing the air dam and it was much easier with it out of the way. For the time to take it off, it's worth it, even if you aren't replacing it.
I used just a small hand wrench. I really wish I had one of the the ratchet wrenches in that size.
Old Sep 17, 2005 | 09:29 PM
STEVEN13's Avatar
STEVEN13
Goose
I did this also. On the pass/side I removed the horn. To remove some of those small screws/bolts I went on the inside-air intake side with a small visegrip and loosen them (not from the hex side).
Steven
Old Sep 17, 2005 | 09:42 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
After I had everything else loose, I took a pry bar and lifted the whole assembly till I could reach them with a gearwrench.
As mentioned, turn the clips around and replace teh screws from under the car.
To '95 Radiator Removal
