Changing brake light on an 86?
Old Sep 17, 2005 | 10:57 PM
The Doberman's Avatar
The Doberman
From: If you run from me, you'll only die tired. North Carolina
Default Changing brake light on an 86?
How the heck do you get to it to change it? From under the bumper I can see where it goes into the back of the light but I sure can't reach it.
Old Sep 17, 2005 | 11:43 PM
rrubel's Avatar
rrubel
You mean the rear lights, not the 3rd brake lights, right? You need to take the license plate off, and then you can reach across to where the bulbs are. It's tight, and someone with long thin arms is best for the job, but it's do-able. I've done the inner two of the four, but not yet the outer two.
I've been told you can take off the inner fender liner on that side and reach it somewhat more easily, but I have not tried that.
[RICHR]
Old Sep 17, 2005 | 11:46 PM
The Doberman
[RICHR]
K I will try. Looks impossible.
vader86's Avatar
vader86
Through the liscense plate.
Old Sep 17, 2005 | 11:47 PM
rrubel's Avatar
rrubel
Not impossible, but not trivial. You have to work by feel.
[RICHR]
Old Sep 18, 2005 | 12:06 AM
The Doberman
My arm is too big to fit
To Changing brake light on an 86?
