I'm just curious - how do you know when (or if) the stock ignition module needs to be replaced? Is it a wear item that needs to be replaced with some frequency, or is it something that normally lasts the life of the car? How do you test one to see if it's gone or going bad?
Mine went two months ago on an 87 with 65,000 on the clock. It left me stranded on the interstate, it provided no warning. I would think about replacing it the next time your doing a cap or wire replacement.
I replaced mine for a higher speck one just for the sake of doing it and keep the old one in the car just incase, it's not a big job to change it roadside if you have to
Did you notice any difference in the way the engine runs after you installed it? Better idle, smoother running, quicker starts, better mileage, etc...?
As was said... you will know when you have to because the car will just die on you, or sometimes it'll work right until you stop the car and it will not start again.
The spark control module is a power transistor switch that connects 12v to the spark coil primary and then rapidly switches off when the distributor pickup coil generates a pulse and the ECM conditions the timing of when to switch off. I do not see how an aftermarket module can do that job any better as it must also have a power transistor to do the switching exactly like the GM module!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!
If there was any difference it was a smoother idle, but I changed it for peace of mind more than anything else .
I replaced mine on my '85 when I bought it 3yrs ago. It was mainly for peace of mind because of the age of the car and the fact I was replacing the cap, rotor, and wires anyway. I'm glad I did because there wasn't that much grease under the module I replaced. It was only a matter of time before it cooked itself and left me stranded!
Its easy. Remove distributor cap, rotor, remove two screws holding the spark control module in, unplug two connectors and then reverse the procedure with the new module.
It won't hurt, but I wouldn't. I drive everyday an 87 and several years ago at about 150k miles it was hard to start and it was the spark control module. If your engine runs fine, let keep on running fine!
Another indication that the module is on its way out -
I was getting a rpm variance similar to a miss right at 2100rpm, I could feel it and watch the tach jump.
With rpm lower or higher no miss, replaced module - gone.
