I'm looking for the cam card for a " Erson" version of the LPE 219 cam I purchased from a forum member. I looked in "search" with no luck. Does someone have specs card for this cam! I need IO, IC points and intake centerline!
I have a jpeg of a 219 cam card, but it is accell. I can email that to you tomorrow.
Remember the erson has 4 degrees built into the cam. Do not install straight up, rather retard it 4 degrees. I lost substantial power by installing it straight up.
Here's a scan of the cam card from my Erson 219. The LCA of 112+4 is cut off just under the grind number. I'll also include a link to a dynamic compression calculator by Pat Kelley and if you enter the Erson specs backed off to 112* you'll see the valve events change to the standard LPE 219 specs.
