Car trouble
Old Sep 19, 2005 | 01:17 AM
Caleb56's Avatar
Caleb56
Default Car trouble
I installed different plugs and gapped them than i installed them and still heard the same ticking but this time a whine sound came also. I than went to check the distributer cap and it zapped me. I looked like this What could be the problem?
Old Sep 19, 2005 | 01:29 AM
Morley's Avatar
Morley
Check the cap for cracks. If none are found, remove the wires one at a time and check for cracked insulation/boots. If they are ok, squirt some dialetric grease up in the boot and reinstall it.
Start the car and see what happens...don't get zapped again...that hurts!
Old Sep 19, 2005 | 01:30 AM
Caleb56's Avatar
Caleb56
thanks for the quick reply but do you think that could be causing the clicking noise?
Old Sep 19, 2005 | 01:57 AM
Morley's Avatar
Morley
Yes, it will cause a "clicking" sound if there is a spark jumping to ground, quite a loud one too.
Old Sep 19, 2005 | 02:20 AM
hippy's Avatar
hippy
Run the car in the dark and you will be able to see much easier if you are getting arching somewhere.
Old Sep 19, 2005 | 02:38 AM
Corvette86's Avatar
Corvette86
St. Jude Donor '06
Old Sep 19, 2005 | 08:36 AM
Caleb56's Avatar
Caleb56
checked the coil for cracks found none. I also checked the boots and found nothing wrong but i did have a problem getting the plugs to click on to the spark plugs. I am using accel header spark plugs with accel 3000 wires.
Old Sep 19, 2005 | 03:19 PM
Caleb56's Avatar
Caleb56
i may have identified the problem the insulation on my ground wire from the coil had melted off. I will check to see if this solves the problem.
Old Sep 19, 2005 | 03:43 PM
VAHROOM's Avatar
VAHROOM
I am betting on a wide gapped plug, bad wire, disconnected wire or somethnig else simple.
Old Sep 19, 2005 | 05:39 PM
Caleb56's Avatar
Caleb56
nope, had my friend check it out whos a mechanic and he tells me its an exhaust leak in my header. I did fix the shocking problem i had earlier
To Car trouble
