Next Mod
Old Sep 19, 2005 | 01:58 PM
RFDrpm's Avatar
RFDrpm
Default Next Mod
So for my next mod I want to do a hot cam, and rockers. Best place to pick on up? Can you get the whole set (cam and rockers) or do you have to buy them seperate. I was thinking hot cam and 1.6 rockers. This is all goning on a '92 coupe w/118 mi. Anything else I should change while im in there? Any suggestions are welcome...
Old Sep 19, 2005 | 03:50 PM
redcorvettedave's Avatar
redcorvettedave
Do a search........tons of info on "HOTCAM" install mod...peace!!!
Old Sep 19, 2005 | 04:17 PM
93 ragtop's Avatar
93 ragtop
Check out this link. http://www.samtaylor.com/html/parts.html
Also you may want to consider a waterpump, optispark, and timing chain set. One other point is go to Nathans home page and read. He has a lot of info on this conversion.
Old Sep 19, 2005 | 04:30 PM
STL94LT1's Avatar
STL94LT1
Also, with 118k miles I would change the lifters
Old Sep 19, 2005 | 05:25 PM
RFDrpm's Avatar
RFDrpm
can you suggest a good lifter, seems to be alot of choices out there..
Old Sep 19, 2005 | 07:44 PM
Alvin's Avatar
Alvin
St. Jude Donor '05
As long as the lifters in decent shape they should be fine. I've seen too many problems especially with *cough**cough*comp R lifters to get me to want to change lifters on a small cam like a hotcam.
You will definately need tuning when you get this done. The 92's are speeddensity and the cam will drastically change the volumetric effeciency of the engine.
To Next Mod
