MSD Timing Question!!
Old Sep 19, 2005 | 03:34 PM
Yournamehear119's Avatar
Yournamehear119
Cruising
Default MSD Timing Question!!
The other day i did two things at once, i added an msd ignition box (6AL) in a rather nice spot too,(right behind the alternator and under the brake booster), and changed my knock sensor because it was throwing a code 43. The knock sensor works to my knowledge, and the msd works to my knowledge. It idles and revs fine, but i havent taken it for a ride yet. I went to go retime it, even though it is roughly 6* (i can tell from how it idles), but when i pull off the est connector, it immediatly stalls and dies. This has never happened before, and im not sure if its the knock sensor (the code 43 disappeared) or if the MSD always does that?
