L98 vs LT 1 Digital Dash Replacement?
Old Sep 19, 2005 | 10:33 PM
1lapRacer's Avatar
1lapRacer
Default L98 vs LT 1 Digital Dash Replacement?
My 91 display (odometer, speedo etc) has quit reading correctly. Have a LT1 display that I replaced it with. It seems to go through the test pattern ok but doesnt read correctly either. Random changing digits for speedo when moving, does not show zero's at a stop.
Is the LT1 display a straight in replacement for the 91. Believe the replacement is a 92 or 94.
Any help would be awesome!
Thanks,
Keith
Old Sep 20, 2005 | 01:48 PM
jrzvette's Avatar
jrzvette
From: The reason time exists is so everything doesn't happen at once
Just a guess but if the old display and the new one are having the same or similar problems I would guess the info feed is bad, not the display.
Old Sep 23, 2005 | 04:20 PM
1lapRacer's Avatar
1lapRacer
Thanks, for the reply. The old unit does not change the values of the display, the new unit has constantly changing data but it is not valid information. It will show 3 digits for the speed while sitting still, the gas gauge will vary showing bars some while not showing the bars between them.
Im going to try the old unit again. Try the new unit, note the differences, check all of the grounds and then maybe buy another unti from a 90 or 91.
Old Sep 23, 2005 | 10:31 PM
-=Jeff=-'s Avatar
-=Jeff=-
the 92-96 LCD uses a different data stream then the 90-91.. when you first turn the key on there is a separate blanking line which is why that looks fine.
Unfortunately you need to find a LCD for a 90-91 to get the display to read properly, unless someone has hacking the CCM code to make the newer LCD panel work..
To L98 vs LT 1 Digital Dash Replacement?
