Accu-sump Plumbing
Old Sep 19, 2005 | 10:46 PM
TRACK MAN's Avatar
TRACK MAN
Default Accu-sump Plumbing
I Want/need An Accu-sump On My Car,, One Guy Said You Can Plumb It Into The Pressure Side?? Of The Oil Cooler.. Is There A Better Place On An Lt-1..... I Dont Want To Take The Engine Out...
Old Sep 19, 2005 | 10:47 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
LT1's don't have an oil cooler, at least both of mine don't.
Old Sep 19, 2005 | 10:48 PM
1991Z07's Avatar
1991Z07
Shouldn't need to take the engine out to get there...
Just need to put a "T" into the line going to the pressue side of the cooler. Plump the AccuSump in and it should work fine.
If yours doesn't have a cooler...put an adapter sandwich plate between the filter and the block. This gives you a pressure & return line to the engine. Put in a cooler and a "T" fitting on the pressure side and plumb it in....
You can do it without pulling the motor...
Old Sep 19, 2005 | 11:18 PM
TRACK MAN's Avatar
TRACK MAN
THE NEXT THING YOUR GONA TELL ME IS THE EASTER BUNNY ISNT REAL SORRY MINE DOES........NO DISRESPECT INTENDED....
Old Sep 19, 2005 | 11:21 PM
the blur's Avatar
the blur
LT1's do NOT have an oil cooler from the factory.
you must have a very rare car indeed
Old Sep 20, 2005 | 12:44 AM
Performance nut's Avatar
Performance nut
I just had one put in. It is a Morosso 3qt accusump. They installed in in the rear on the crossmember by my spare tire carrier (had to remove spare tire carrier). The accusump is connected at the oil temperature sensor. Looks pretty good to me, cant really see it unless you get down low and it is well protected. If you like, I can send you pictures later this week of it.
Old Sep 20, 2005 | 10:53 AM
luvmy92's Avatar
luvmy92
That's how mine is done as well.
I just ran it for the first time with the oil cooler and accusump this past weekend at Sebring in 100 degree heat.
210 water temperature
253 oil temperature
40 psi oil pressure in some of the high G corners
I am very happy with the results.
Mike
Old Sep 20, 2005 | 11:45 AM
Ramrod92's Avatar
Ramrod92
Cruise-In II Veteran
I think what Frank was trying to get across is that LT1 vettes did not come stock with an oil cooler. Not sure, but I think the F-body LT1s might have one though.
Old Sep 20, 2005 | 10:14 PM
TRACK MAN's Avatar
TRACK MAN
253 oil temperature
Mike
WOW AWSOME TEMPS I HAVE A $2,000.00 RON DAVIS RAD AND OIL COOLER SET UP AND STILL RUN INTO THE 220-225 RANGE
Old Sep 20, 2005 | 10:23 PM
TRACK MAN's Avatar
TRACK MAN
YES I WOULD LIKE TO SEE IT, MOST IVE SEEN USE A LEVER TO RELEASE/STORE THE PRESSURE HOW DOES YOURS WORK I HEARD OF ELECTRIC SWITCHES, THAT OPEN AND CLOSE VALVE WITH THE KEY ON/OFF.....
Old Sep 21, 2005 | 12:31 AM
Performance nut
Yep. Its got an a solenoid valve which is hard wired to my ignition and has a manual switch. Very nice setup. Send me your email address via PM and I will send you some pics. Heck, if someone doesnt mind hosting it, they can be put on this thread.
Old Sep 21, 2005 | 08:31 AM
luvmy92's Avatar
luvmy92
Mine is also in the rear where the spare tire used to reside. It too has the Electronic Valve with the manual switch in the cockpit.
Parts List from Canton:
Part Description
24-006 3 Qt Accusump
24-273 E.P.C Valving kit
24-200 Mounting Clamp (pkg of 2)
23-605 -10 Stainless steel braided hose ($15/ft)
23-245 1/2" npt to -10 AN steel adapter fitting (2 x $4.50)
23-725 Brass push in hose ends (package of 2)
22-550 SBC Oil Input adaptor
Plus numerous AN fittings. BTW, I have a Be-Cool radiator with a 160 stat, and use 90/10 water/antifreeze with 2 bottles of water wetter.
Mike
To Accu-sump Plumbing
