Difference in B-body LT1 blocks
Old Sep 20, 2005 | 09:58 AM
ScaryFast's Avatar
ScaryFast
Default Difference in B-body LT1 blocks
I'm looking for a new LT1 due to a spun bearing (see other thread: http://forums.corvetteforum.com/show...56&forum_id=48)
I found a few B-body LT1's locally. A forum member mentioned that there are two versions of that motor, one is not a true 350. Can someone point out the differences so that when I take a look at these motors I can ensure I'm looking at the right one?
Thanks!
Old Sep 20, 2005 | 10:01 AM
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
Thanks!
The B-bodies could get a L99 4.3L LT1 style motor as well as the 350. Some prefer the F or B body LT1 as they are 2 bolt and then thry machine the block for 4 bolt splayed caps.
Old Sep 20, 2005 | 11:46 AM
MYCoupe's Avatar
MYCoupe
The 4.3 L block has a much smaller bore (3.75" vs. 4.00") than the 5.7 L one.
Old Sep 20, 2005 | 01:12 PM
ScaryFast's Avatar
ScaryFast
Thanks for the info. If the motors are assembled so that I can't measure the bore are there any other signs or markings, numbers, etc on the block I could see?
For a stock HP motor is it necessary to go to the 4 bolt? I'm going to turn my current 4 bolt motor into a stroker, this one's just to get me by.
Thanks again.
Old Sep 20, 2005 | 01:49 PM
93Polo's Avatar
93Polo
CI 3-4-5-9 Veteran
Thanks again.
A 4 bolt is not needed for a driver. The 2 bolt caps can actually take quite a bit of power.
Sorry I can't help you out on telling the L99 apart from the others.
Old Sep 20, 2005 | 02:23 PM
CorvetteKid1983's Avatar
CorvetteKid1983
Casting Numbers on block:
10168588 = 265 ci, 1994-1996, 2 bolt, L99, Gen II, 4.3L, B-Body, Reverse Flow Cooling
10125327 = 350 ci, 1992-1996, 2 bolt (B & F Body) & 4 bolt (Y Body), LT1, Gen II, 5.7L, Reverse Flow Cooling
10125327 = 350 ci, 1996, 4 bolt, LT4, Gen II, 5.7L, Reverse Flow Cooling
The block code, which is stamped on top of the passenger side of the block at the rear, is just behind the intake manifold.
Take Care!
Old Sep 20, 2005 | 03:57 PM
ScaryFast's Avatar
ScaryFast
Kid -
Thanks a million. I'll check the numbers.
Old Sep 20, 2005 | 08:52 PM
Mr Mojo's Avatar
Mr Mojo
Elite Torch Red Member
Cental/South NJ Events Coordinator
CI 1-2-3-4-5-6-7-8-9-10-11-12 Vet
CI-II Burnout & Drag Champ
St. Jude Donor '03-'04-'05-'06-'07
http://www.automotiverebuilder.com/ar/ar99928.htm
Old Sep 21, 2005 | 10:54 AM
ScaryFast's Avatar
ScaryFast
Mojo that's a great link. Thanks.
The motors are the 5.7L block, iron heads. I"m discussing whether or not it's worth swapping my cam into the motor or just dropping it in stock and working mine completely.
280 hp sounds sooo low...
To Difference in B-body LT1 blocks
