Can I re-use these gaskets?
Old Sep 20, 2005 | 10:00 AM
hz900's Avatar
hz900
Default Can I re-use these gaskets?
This may seem like a stupid question, but can I re-use a set of head gaskets if all I did was bolt the head on the engine a couple weeks ago only to take them off this coming weekend? Engine has never been ran. Thanks
Old Sep 20, 2005 | 11:28 AM
Dynabob's Avatar
Dynabob
From: What do I know anyway? I'm just a 50 year old No0b
Are they copper gaskets? Supposedly copper gaskets can be re-used but I wouldn't trust it myself. Especially if you have aluminum heads. For all the potential trouble that may happen I would consider it cheap insurance to use new gaskets. The ones you have now have already been 'crushed' and may not seal again. My .02
Old Sep 20, 2005 | 11:32 AM
newbecorvetteguy's Avatar
newbecorvetteguy
Probably could but it depends on (1) do you feel lucky? (2) how many times to you want to take it appart? I doubt re-using it would be recommended. For me, if it's the lawn mower that I can take appart in 5 minutes, I'd re-use it. On a modern car where the engine is buried under a mountain of cr*p to begin with, I think I'd spend the money and replace it. My experience has been when I don't have enough time or money to do something right, I still always time to do it over. It would probably be ok, but I don't think I would try it myself. jmo
Old Sep 20, 2005 | 12:10 PM
Pete K's Avatar
Pete K
Absolutely NO !
Old Sep 20, 2005 | 12:11 PM
vader86's Avatar
vader86
No.
Old Sep 20, 2005 | 12:18 PM
TorchRedlt4man's Avatar
TorchRedlt4man
From: Chicago Executive Airport, formerly known as Palwaukee
No-IL Events Coordinator
St. Jude Donor '12-'13-'14-'15-'16-'17
Old Sep 20, 2005 | 12:20 PM
aboatguy's Avatar
aboatguy
They may seal; but do you want to take that risk?
I would buy new gaskets!
Mike
Old Sep 20, 2005 | 12:21 PM
aboatguy's Avatar
aboatguy
The old gaskets may seal; but do you want to take that risk?
Mike
Old Sep 20, 2005 | 12:27 PM
kopbet89c4's Avatar
kopbet89c4
Is this the same with intake gaskets? How many people reuse those ones, especially on the SuperRam? I already know that it is bad to reuse head gaskets.
Old Sep 20, 2005 | 12:34 PM
hz900's Avatar
hz900
I figured I needed new ones, just wanted to verify before I spent even more money on this project.
As far as the intake gasket is concerned, most people use RTV on them and if you try to take them apart its just a mess, usually end up tearing them.
Old Sep 20, 2005 | 02:39 PM
FDAMFA's Avatar
FDAMFA
Since you got the heads of put new gaskets on--a no brainer, better safe than sorry
Old Sep 20, 2005 | 03:04 PM
65Z01's Avatar
65Z01
Cruise-In II Veteran
For head gaskets I would NOT reuse them even if the motor had not been run.
I reuse the "upper" intake gaskets (runners & TB) on my stock TPI until they begin to disintegrate. But always use new base to head gaskets.
Old Sep 21, 2005 | 04:30 AM
dand1892's Avatar
dand1892
all true u would have reused upper intake but could only get a set with the lower one that no one carried except napa
To Can I re-use these gaskets?
