EGR Question
Old Sep 20, 2005 | 10:09 AM
RFDrpm's Avatar
RFDrpm
Default EGR Question
What happens if I block off the egr and dont use it? What else do I have to change?
Old Sep 20, 2005 | 11:25 AM
vader86's Avatar
vader86
You'll need the chip programmed to take out the Code 32.
Old Sep 20, 2005 | 11:41 AM
Red Tornado's Avatar
Red Tornado
also be prepared for the possibility of pinging/detonation, as your combustion temps will most certainly go up. removing egr is probably more trouble than its worth........or so i've read.
here's one read, scroll down to last section "other notes":
http://sethirdgen.org/egr.htm
Old Sep 20, 2005 | 11:53 AM
RFDrpm's Avatar
RFDrpm
Well, since I have to pull the head to get the D@#M header bolt removed, it shouldnt be so bad to get the EGR back on the back of the block. I think Ill just keep it...
To EGR Question
