I've checked w/my local dealer and they can't get, for my '89, the clamp that joins the pipe that runs up from the cat conv. to the check valve for the AIR system that is next to the right exh. manifold. A friend of mine called it a "crimp" clamp. Any ideas on how to attach the pipe and valve?
If you're just trying to "join" the pipe and the gap is less than an inch, you can probably get by with a Swagelok union compression fitting; I believe its 1/2" tubing from the main cat to the air pump.
I had to do this on my 89 when the shop that replaced my cat just used a strip of Dr. Pepper soda can and hose clamps.
Sounds like the right sort of thing...and the pipe OD is what you said (1/2"). I did a Google search and couldn't find it easily. Any tips on how/where to get one?
Any hardware store; Home Depot, Lowe's.... should have them.
Just ask for 1/2" union compression fitting. Swagelok is just a trade name.
If the gap is too wide for the fitting, then you will need 2 fittings and a section of 1/2" tubing for a sectional patch. I was fortunate enough that mine only had a 1/2 inch gap.
I got a new one in the box with my Random Tech hi flow cat that I bought from TPIS. I know TPIS sells the EGR crimp ring, they might sell this one as well.
yes, I'm almost certain that it's the same clamp on the other end. Thank you!
