AC lines frozen..HELP!!!
Old Sep 22, 2005 | 12:56 AM
yellow dragon's Avatar
yellow dragon
Default AC lines frozen..HELP!!!
I just got a service engine soon light on my '91 TPI, and i checked the engine bay and found thick frost over the lines comming from my AC pump, and the rubber lines are solid with ice. what could the problem be and how might i fix this? please help!!!!!
Mark
Old Sep 22, 2005 | 02:43 AM
Aggravated4life's Avatar
Aggravated4life
Cruise-In II Veteran
TTT... maybe SunCr can help you.He's the a/c expert around here.
Old Sep 22, 2005 | 03:34 AM
Morley's Avatar
Morley
Freon charge is low.
Old Sep 22, 2005 | 03:40 AM
yellow dragon
thanks,
could that cause a service engine soon light as well?
Old Sep 22, 2005 | 03:43 AM
Morley's Avatar
Morley
Originally Posted by yellow dragon
thanks,
I wouldn't think so, unless the ice melted and water got in/on something that doesn't like it...Pull the code and post it here.
Old Sep 22, 2005 | 03:56 AM
yellow dragon
having trouble pulling the code, correct me if im wrong, i jump the two top right terminals and then read the code?
Old Sep 22, 2005 | 09:28 PM
Biff Buyer's Avatar
Biff Buyer
defiently low refrigerant, does that 91' still take the old outlawed kind or is the new r134?
Old Sep 23, 2005 | 03:27 AM
yellow dragon
OUTLAW.. and its wanted, dead or alive!!!
im sure i can scrounge some up.
thanks for the help!!!
Old Sep 23, 2005 | 06:17 AM
Atok's Avatar
Atok
Mark
Check your codes. More than likely you have a bad A/C pressure sensor.
Old Sep 23, 2005 | 07:22 AM
runner140*'s Avatar
runner140*
Low gas but you need to pull the codes first.
Old Sep 23, 2005 | 06:02 PM
yellow dragon
gave me a code 32, EGR valve, so not related, my climate control gave me no trouble codes.
Old Sep 23, 2005 | 09:11 PM
snoopy2003's Avatar
snoopy2003
Its not low on freon, it is your ac sensor on the high pressure side. the ac system is supposed to cycle if it doesn't cycle it will freeze up like your system is. Low freon would cause no or very little cooling or frost. Your system is just staying on and not cycling on and off causing it to freeze up
To AC lines frozen..HELP!!!
