fuel pump question
Old Sep 22, 2005 | 01:17 PM
cjg454ss's Avatar
cjg454ss
Default fuel pump question
i have a vortech kit, im going to run stock boost and put 30 lbs injectors in it. will the stock pump be able to handle it. if not what do you gus recomment as an upgrade.
Old Sep 22, 2005 | 01:51 PM
drochau's Avatar
drochau
If you're running an FMU it will up the fuel pressure sufficiently to support your setup, however in most cases the fmu is simply a band aid. To ensure that you have enough fuel delivery to the injectos for now and in the future (too 600fwhp) I would reccommend the racetronix 255lph walbro kit. It's cheap insurance that the fuel will be there if you need it (120ish).
-Dave
Old Sep 22, 2005 | 04:06 PM
mn_vette's Avatar
mn_vette
There should be a booster pump with the vortech system. If you don't have that I'd recomend upgrading to a Walbro 255LPH pump, Get the High pressure(HP) model.
Old Sep 23, 2005 | 03:34 AM
Mo_Bandy's Avatar
Mo_Bandy
with both posts... I went with the pumps and I'm runnin 36 lb injectors , as I didn't want to have to run 65-75 pounds of fuel pressure...
Mo
To fuel pump question
