vss
Scott
OK now were getting somewhere. Of the four different types of sensors, two of them cover 2.59 - 2.73 Gear Ratio, ( one pre 90 #25007224 and 91 and on #10456091) That leaves us with two, old and new style,or old #25007308 and new #10456089. These are for the 3.07 - 3.45 Gear Ratio. As mentioned above the driven gear is the same on a 94 that uses the same sensor as the 91 or # 10456089. Now the sticky part,the signal or pulse goes from vss to ecm. I find that the ecm on 1990 is the same as 1991 but call for the different vss respectively. A little hard to follow but, I'm thinking this might work.
I was using this chart I found here Thanks to James93lt1 in a reply to macvettes http://www.corvetteforum.net/c4/vet...rGearshtm.shtml
concerning 1993 Speedometer Gearing - Which Gear??? on 9-22-05
so whaddya think? Could this work?
It appears I erred when I said there were 4 VSS's. There are at least 5 and probably a total of 6. It seems, as per that chart, when they changed the pulses per revolution, they also changed the fitments between the auto and manual transmissions. I have found few errors in that chart. If you install the parts called for, for your year car, transmission, tire size, and axle ratio, you will be happy with the speedo operation.
I don't know how the VSS is wired. I cannot comment in whether your ECM is the same as anything else, But I'll guarantee you if you sub VSS's with no other changes, your speedo won't work properly. GM didn't change the part number to test YOU to see if you could sub it for another. There are other factors that allow for different gears in the 1994. Stick to what YOUR car takes and all will be well.
RACE ON!!!
