"Centrifugal supercharger" Question...
Old Sep 23, 2005 | 12:10 PM
Casethecorvetteman's Avatar
Casethecorvetteman
Default "Centrifugal supercharger" Question...
I have a 94 with a few mods, but my biggest question here is, if i installed a centrifugal supercharger, will the engine run properly if it is piped from the supercharger to the throttle body going through the MAF or do i need to use speed/density instead? I have allways wondered this as it is obviously a concern for me if i decide to fit a supercharger on my 94
Old Sep 23, 2005 | 12:27 PM
bacardioil's Avatar
bacardioil
call greg at blower works. great guy. ( greg@ blowerworks.net )
Old Sep 23, 2005 | 12:51 PM
mn_vette's Avatar
mn_vette
Wow, that seems to be the answer to everything around here lately.
The answer to your question is yes you can still use your MAF sensor. I believe people get better results if you put the maf before the blower. There are kits out there for the '94 vettes. Blowerworks makes a nice kit, or you can go the Procharger way or even a vortech kit, or build your own.
Old Sep 23, 2005 | 02:05 PM
Casethecorvetteman
Expensive phone call from here mate!! Im in Australia...
Old Sep 23, 2005 | 03:17 PM
AKS Racing's Avatar
AKS Racing
The car can be made to run with the MAF. Procharger's kits route the discharge through the MAF. SD is nice for heavily modified cars, but is not the only way to go.
I ran for years with the blower pushing through the MAF.
Aaron
Old Sep 23, 2005 | 04:17 PM
bacardioil's Avatar
bacardioil
you know the old saying you get what pay for and if you want to play , you have to pay.
Old Sep 23, 2005 | 07:56 PM
BrianCunningham's Avatar
BrianCunningham
From: Boston, Dallas, Detroit, SoCal, back to Boston MA
Just make sure of the BOV placement, so the engine doesn't think the air it's getting rid of is going through the engine.
Old Sep 24, 2005 | 01:59 AM
Mo_Bandy's Avatar
Mo_Bandy
You can run a MAf with a centrifugal... I'm doing it now... You as posted above need to route the bypass valve to a the intake just past the maf to be sure the MAf is metering everything right.... ( otherwise it will try to compensate and run very rich.
If you pull more than I believe it is 370 gm/secit will set a code, but it can be resolved with lt1 edit...
also as posted you an put the MAF post Superchareras well... I run mine down near the airfilter...
If you go to the vortech supercharging site, under support they have the installation mnual you can download, that help explain this a bit more...
please fee free to email me if you need more info...
Regards,
Mo
Old Sep 24, 2005 | 09:38 AM
Casethecorvetteman
Regards,
Mo
So it apears the best way to have it is with the supercharger sucking the air through the MAF rather than blowing into it, would this be correct?
Old Sep 24, 2005 | 11:02 AM
Mo_Bandy's Avatar
Mo_Bandy
That is the way it is " traditionally " done yes.... However, the Maf really doesn't care. I would personally think that in terms of "stability" of the air drawing itthrough the MAF would be the best way to go..
REgards,
Mo
Old Sep 24, 2005 | 03:25 PM
TheCorvetteKid's Avatar
TheCorvetteKid
Forgive me from starting from the beginning, but I have to ask - do you HAVE a MAF on the car right now? The reason I ask is because I believe that '94s used a MAP system (no MAF). A MAF is not a requirement for using a centrifugal supercharger. It does make tuning a bit easier, but it isn't critical.
However, if you DO have a MAF on the car now (or just want to run a MAF when you run a centrifugal supercharger), then the MAF is mounted between the supercharger output and the throttlebody. Mountng a MAF on the intake side of the supercharger is NOT a good idea. Centrifugal superchargers do not pull alot of vacuum on their intake side. A good way to think of it is that centrifugal superchargers hate to suck, but they love to blow. So by mounting a MAF in the intake side of the supercharger, you won't get the proper metering of the amount of air entering the engine. By mounting the MAF in the air stream between the blower and the throttlebody allows the MAF to provide the ECM with the proper amount of air entering the engine.
But again, using a MAF with a centrifugal supercharger ISN'T a requirement. A MAP system will work just fine (as long as you can tune the system).
Hope that helps.
Old Sep 24, 2005 | 04:44 PM
Mo_Bandy's Avatar
Mo_Bandy
I didn't really explain that, yes if you dont have a MAF it is not required.
Vortech and the others mount the Maf behind the air cleaner before the supercharger (which is where I have mine),but again I beleive it is because the air is less turbulant there. It's a matter of tuning... mine seems to meter fine where it is... as I mentioned about there a couple schools of thought on this... HEH...
regards,
mo
Old Sep 25, 2005 | 07:50 AM
Casethecorvetteman
[QUOTE=TheCorvetteKid]Forgive me from starting from the beginning, but I have to ask - do you HAVE a MAF on the car right now? The reason I ask is because I believe that '94s used a MAP system (no MAF). [\QUOTE]
Nah youre wrong about that one little bit there mate, 94's went back to MAFs and ALSO have a MAP as a backup. So yep, it sure does have a MAF !!! Thanks for your input though, i apreciate it.
Old Sep 25, 2005 | 08:59 AM
TheCorvetteKid
Vortech and the others mount the MAF behind the air cleaner before the supercharger (which is where I have mine)...
You'll have to fogive me Mo, but I've never seen a setup like that. All the superchargers I've seen have had the MAF mounted between the blower and the throttlebody.
I knew they went back to a MAF setup, but I wasn't sure what year. I always thought it was only in '95, but I guess I was wrong.
Have you sent Greg at BlowerWorks an email about your concerns? Obviously calling him for where you are would be pretty expensive, but Greg is pretty good when it comes to emails. I've had correspondence with Greg several times via email just over the last two weeks. Try it: greg@blowerworks.net.
Good luck.
Old Sep 26, 2005 | 01:15 AM
Mo_Bandy's Avatar
Mo_Bandy
Hey Corvette kid,
No problem, if you look at my website ( in my signature), you can see how the Vortech is... right after the head there is a extruded aluminum housing that joins the output of the S/C right up to the throttle body... there is a bypass vavle that then reroutes the air that is by passed when not under boost back thorugh basically recycling it until the bypass valve closes. It may e different on the earlier C4s with L98's...
regards,
Mo
Old Sep 26, 2005 | 09:52 AM
Casethecorvetteman
here is a pic of the engine just for the sake of showing all of you how mine looks....
All this was done when i bought it.You might notice a couple parts out of place(brake booster for example!!),this is due to the fact the steering wheel has been put on the right hand side where it belongs....
Old Sep 26, 2005 | 09:57 AM
neat's Avatar
neat
I don't think this is correct. The supercharger system is sealed. There is no way for the engine to ingest air without it first coming through the supercharger. If you meter all the air entering the blower, your MAF reading should be right on the money. If you use a blow off valve, you'll run into problems when it opens, but other than that, you should be good to go.
Am I wrong?
To "Centrifugal supercharger" Question...
Old Sep 26, 2005 | 10:52 AM
Casethecorvetteman
Am I wrong?
Sounds about right, but this now brings me to the next question, why would i want a blow off valve?? Ive never heard of that being needed on a centrifugal supercharger before... And if the blow off valve is open, the supercharger would be sucking air through the MAF, and blowing it out the valve and still giving an incorrect reading wouldnt it?? With my car using both MAF and MAP, this may set off some kind of code to sugest an irregualarity....
Old Sep 26, 2005 | 01:40 PM
neat's Avatar
neat
When you have pressure in the intake tract, and the throttle body blades snap closed, that pressure has to go somewhere. Normally, it goes back into the blower. With some high boost applications that can cause damage to the head unit. It's probably not a good thing to have happen at any boost level though. The BOV open and vents that pressure when you let off the gas. It'll only be open for a second, and it will cause a rich fuel condition for a second because it's letting air the MAF 'saw' escape without going through the motor. The computer will supply the fuel for the escaped air. Make sense?
Old Sep 26, 2005 | 10:34 PM
Mo_Bandy's Avatar
Mo_Bandy
Correct -a- mundo !
Mo
