For the past week or so i have had a small coolant leak. All the hoses and hose clamps are brand new, tight and not leaking. The intake, thermostat and throttlebody gaskets have all been replaced. The coolant seems to coming from the top of the engine and dripping down. Im just wondering if anyone can think of any places it could be coming from. The circled area in the picture i have posted shows where the coolant is sitting and dripping down. Any suggestions would be great!
for a couple of years. At first I thought it was the stat housing also but it turns out it was the manifold to head joint. The factory installed bolt in front was only slightly tighter than hand tight. But tighting didn't help, I had to pull the intake and redo using Fel-pro intake set.
Before doing that, I think I'd try removing the one bolt and putting thread sealer on the threads, and a little rtv form-a-gasket between the head of the bolt and the intake. Being cheep and lazy, I'd try cheep and easy before moving on to harder and more costly. If this is the source of the problem, replacing the gasket is probably the more 'right way', but the suggestion I made might be enough to address the complaint.
My son's gmc truck was leaking coolant past the threads on the intake. He wanted an edlebrock intake and carb anyway. Replaced the whole works including new bolts. Same leak. Did the thread sealer and rtv thing and no more leak.
