My first C4, starter woes...
Old Sep 23, 2005 | 02:55 PM
thebmwsource's Avatar
thebmwsource
Default My first C4, starter woes...
I'm a C3 guy with my first C4. My ploblem is the starter sometimes will disengage slowly. It's slow enough that it will grind the flywheel for a fraction of a second. My starter guy has rebuilt the starter and says it checks out with a load. He thinks it could be voltage drop at the starter or a bad flywheel. Am I at least going in the right direction?
Old Sep 23, 2005 | 05:16 PM
byebyeL98's Avatar
byebyeL98
St. Jude Donor '10-'11-'12-'13
What year is your C4? Without juice, that starter gear should be snapping back into place. Does it engage smoothly?
Sounds like you're headed in the right direction so far...
Old Sep 23, 2005 | 05:17 PM
SJW's Avatar
SJW
I doubt it's got anything to do with a bad flywheel, if I'm understanding you correctly that the grinding occurs when you let off of the key.
And a "voltage drop"??? There should be no voltage applied to the starter anytime except when the key is in the Start position.
More likely, it's something sticking in either the solenoid, its linkage, or the Bendix is binding on the armature shaft.
Does the ignition switch seem to return from Start to Run normally, or is it perhaps sticking a bit?
Be well,
SJW
Old Sep 23, 2005 | 06:53 PM
thebmwsource
The car is a 92. It is grinding after I let off the key. The key seems to be returning like it should. It doesn't do it all the time. Do you think my starter guy may have missed something in the rebuild? Yes, it does engage smoothly.
Old Sep 23, 2005 | 07:31 PM
Redeasysport's Avatar
Redeasysport
St. Jude Donor '05-'06
Bad rebuild
Old Sep 23, 2005 | 08:00 PM
jackdaroofer's Avatar
jackdaroofer
From: Almost all Skyline Cruises Vettes at Waterside 1-5
Cruise-In I Veteran
Cruise-In II Veteran
Cruise-In III Veteran
Cruise-In IV Veteran
Cruise-In V Veteran
Cruise-In VI Veteran
Cruise-In VII Veteran
There are shims (very common) that are used to be sure starter and flywheel are in correct alignment.
Sounds like you may have a misalignment.
The GM shop manual addresses this problem
seeya
jack
Old Sep 24, 2005 | 01:07 AM
SJW's Avatar
SJW
Originally Posted by Redeasysport
Bad rebuild
I'd have to agree. My money's on a fault in the starter or solenoid.
Be well,
SJW
Old Sep 29, 2005 | 07:06 PM
thebmwsource
Default Starter #2, same grinding..
I put another starter on (ac/delco). Same grinding noise about 1 out of 5 starts. No shims were added. Is it shim time? My mechanic thinks it has to do with low voltage. He told me the solenoid engages and disengages the drive gear. He thinks that low voltage is causing the starter to hang. Any input would be greatly appreciated.
Old Sep 29, 2005 | 07:14 PM
Redeasysport
Is it better or worse or exactly the same?Could be shims mabey were there any in it to start? Low voltage is BS 12v is 12v it should not hang.Did you replace the solenoid too or just the starter?Could be bad solenoid they can weld over.
Old Sep 29, 2005 | 07:23 PM
thebmwsource
Sounds pretty much the same. There were no shims on the original starter. Everything is new, starter/solenoid wise.
Old Sep 29, 2005 | 07:47 PM
Redeasysport
You can try putting a shim in to move it away from the flywheel and see how that works.I would not move it too much because you will start grinding teeth off off the flywheel.
Old Sep 30, 2005 | 10:53 AM
SJW's Avatar
SJW
There should be NO voltage feeding the windings of the solenoid when the key is in any postion other than START. When you back off the key to the RUN position, it's the disappearance of voltage at the solenoid's windings that causes the starter to disengage.
Be well,
SJW
To My first C4, starter woes...
